          I wont swear on line, but on taking the engine topieces - I checked how smoothly the oil pump turned and it was very stiff and notchy so I thought that I would take the pump to pieces but, and guess what, I broke the upper casting, now two things
Firstly - Are replacements available and from whom?
Secondly - How do you trake the drive shaft out of the casting?
Thanks for any help
Charles
You might try Pushrod Perf…
Charles, I think I have an…
Charles,
I think I have an incomplete and partially dismantled oil pump somewhere. Can you e-mail me a picture of the bits you need?
Charles If you get complet…
Charles
If you get completely stuck, Stu Rogers 01945 585116 can supply new ones.
Roger
You might try Pushrod Performance : http://www.pushrod-performance.co.uk/
Skip Brolund
