Wheel bearings
Hi All, does anyone know the bearing numbers for front and rear wheels for a 1960 ES2?
Thanks Rob
Does that have the double row in one side and the single row in the other as on the earlier ones? If so its 6203 2RS and 4203 2RS. Or you can type the dimensions into Simply Bearings and that gives you the numbers I think.
The front and rear bearing sets are the same:
Front off side: pn 17721 17x40x16 DBL Row
Front near side pn 17719 17x40x12
Rear off side pn 17719 do
Rear near side pn 17721 do
A good bearing shop should be able to match them up for you.
Get a "sealed both side" type and never have to re-grease them again.
Or you could simply go to the NOC Shop on this web site and order your bearings from the club spares scheme.
Colin.
