Anyone!
A friend needs a new (replacement) oil tank for his Big4.
If you have anything available please let me know!
Cheers,
Pauli
Previously wrote: Richard,…
Richard,Thanks for the tip - we'll be careful!
I don't have one at the moment but if you find one, be careful that civilian frames from 1936 onwards had horizontal lower rear saddle spring mounts and these prohibit the use of the WD 16H type oil tank (the majority to be found are ex-WD).
The later oil tank has a shorter neck which is located slightly more to the rear.
