M18 Rocker Box
Hi all, and I'm thinking the wizard Richard Cornish may be able to help!:))
Starting to reassemble my 38 model 18 with a 47 engine.
Looking at my nice model 18 completed there is a quarter an inch gap between the rear fuel tank mount and the top of the rocker box.
on my project bike there is absolutely no gap so I've had to drop the engine to get the rocker box off, which I did take off and put the engine back up onto the mount again. There is just no room the bolts are correct diameter and everything is fine at the bottom. It's just that there is no way to remove the rocker box if I did put it on as it is touching.
when I've got the project bike, it was all mounted apart from the rear engine plate plates which were hanging off so I'm wondering if it was mounted properly,
I've had the frame repaired and the gearbox mount tube  re-tubed with the engine cases so it aligns correctly via Jake Robbins Engineering
What are your thoughts?
hopefully the pictures are clear enough
Hi Matthew,
   Wiszard ? no, it's all smoke and mirrors !!
Looking at the your first photo I think your frame might possibly be a WD16H, although not all the frame is visible to say for certain. There are at least 4 variations of the diamond pattern frame and these vary by the height of the front down as a quick reference. This is measured from the bottom of the head-stock casting to the top of the engine mounting lug. The first thing will be to check the frame number with the factory records to get a confirmation of what model it actually is.
Hi Richard, thank you so much again the frame number is 86855 Which I believeThe frame number indicates a prewar frame from Dec 1937 to early January 1938.
Gawd i hope its a M18:))). I decided to clean up the wheels to see what's underneath and there is green paint and also the rear bearing cover is a large disc not like my model 18.
Do the pictures, help a bit more
What are your thoughts, sir?
Dave Graham fitted a 1938 pattern Model 18 engine into a WD16H frame to replicate one of the small batch of WD18s produced in September 1939. I'm sure he mentioned that there were casting differences to the rocker boxes on the ostensibly similar post-war engines (which were all installed in full cradle frames) and the later rocker box would not fit in the WD chassis.
86855 falls between a couple of WD batches, but you have horizontal saddle spring mounts and the tall pillion footrest lugs (to clear the "Cow's Udder" silencers) so I'm sure you have a civilian frame.
Your engine plates with detachable footrest tubes are the WD type. I'd have expected some dimensional differences here to accommodate the WD main frame upright tubes being 1" shorter. If the frame has been tweaked to accept them then perhaps that might not be helping ?
Thank you Richard. I didn't ever know they made a WD18.
The engine plates are only being used for dry fitting and will make the tubes and weld to the plates as the same as my other 38.
So what we're saying is there is potentially a different shaped rocker box or is this going to be super rare?
As it is, the engine and Rocker box will not go in Even the very last Resort of filing down the fuel tank this is something I do not want to go down at all.
I would rather locate the correct components, what are your thoughts?
cheers
Hi Matthew,
   Richard Payne has the most knowledge and information of these models, but there are a couple of details that might be worth looking into. Norton could supply all models in the range to Trials specification from the early 1930s. Looking at your photos, the exhaust port looks too high compared to the front petrol tank lug when you look at other Model 18's of this period. If convenient you could compare the front down tube length with your restored model. Chris Streather should be able to check your frame number.
Yours has the hand wheel knob on the fork damper, not the hex nut used on later WD bikes.  Is that significant?
Hi Richard, thanks for that. Okay I will measure the down tube and do a comparison..
What I have picked up from all this valuable information that the lugs are high to enable the rear foot pegs to clear the cows udder exhaust
A possible potential of a WD 18 Variant with a different rocker box it looks like these were only made in September of that year for literally only days.
let's see what Chris S comes back with Richard
Hi Richard.
Okay, so I think this is a disaster sadly.
I've measured my nice Norton and it's 31 1/2 cm from the fuel tank mount lip ( tube inside) And the project one is 29 1/2 cm. .
I just don't know where to go from this Really yes, I'm sure I can make the engine fit, but something is majorly wrong either. It's a 16H or WD18 With a different rocker box.
I've attach some more pictures for some clues if that helps
Hi Richard and team!
I just wanted to send a couple of pictures which really clarifies how far this is out.
I've rested a bolt on top of the exhaust to the side car mount and you can clearly see the difference the straight one being the project bike.
Secondary picture is my nice M 18.
This is clearly not right, It has to be a 16 H just by going on the pictures I believe.
The 1938 parts list has two open frames.
8962 for 1, 16H, 18, 19 and 20
8968 for models 50 and 55.
So it looks like the 350cc models had smaller frames, since engine size was the only difference between models 18 and 50.  Perhaps yours is a Model 50 frame?
The Factory Records will identify what model the frame is.  The only difficulty is that as the prewar records are recorded by engine number, finding a frame number takes time.
As a group  of us club members put the records into Excel spreadsheet format about 20 years ago, searching this format will simplify the task.
Who in the  club has all of the data that we transposed all those years ago?
Hi Ian and David
Thank you for that. I've contacted Chris Streatham And he is currently looking at what he has. There was no definitive answer in his answer phone message but was slightly in the direction of a WD 18 unconfirmed. I'm not sure and he did say the engines in the frames were extremely tight.
All I need is another few millimetres but to do the job right I'm gonna wait to see what he comes back with and then make a plan of attack. What to do as I know if I make the wrong decision I will only regret it,
Hi Matthew/all,
   The Model 50/55 crankcases are smaller than the 500cc engines and the frame has slight differences so that the 500cc engine will not fit with-out the frame being modified where the crankcases fit.
The other open frames were WD16H and post war 500T and possibly pre-war trials variants, which Matthew's frame might be.
Not sure but I would think the Machine Records Officers use the Excel data, but best to contact them.
This is definitely not a British Army (War Office) frame as they all used the 1936 pattern with vertical saddle spring lugs. The WD18s were built into frames intended for a WD16H contract and a surviving example showed that it had standard WD16H dimensions.
The easiest way to compare frame sizes is between the bottom of the fuel tank lug and top of the front engine mount lug.
The only possible source of a high ground clearance military frame with horizontal saddle spring lugs might be one made for the India Office during 1938 - 1939 as they used the later type. I don't think it's known if they were higher clearance.
Peter Roydhouse once told me that few of the pre-war bikes to "Trials" spec had high-clearance frames but presumably some did.
Has Chris not been able to find the frame number in his records ? We're assuming that the number is a factory stamping, but it has rather a lot of paint on it for me to be 100% sure.
