Hi
My Norton Commando MK3 alternator has failed. I have taken the opportunity to upgrade this to a 3 phase alternator and associated regulator/rectifier
The new alternator has 3 wires rather than 2 so I need an extra cable from the regulator/rectifier to the alternator.
The current 2 wires seem to be made up of a pair of wires each, one end has both wires in a spade connector the other end goes to a double bullet connector. As the alternator only uses one side of the double bullet connector is it safe to say it only needs one of the wires if so can I cut of the spade connector and bullet connect and use the 2 wires as separate connections.
If not I will need to run a new cable from battery area to alternator do you know what size cable this would need.
Mark
A photo will be helpful
Yes, photo
Mark,
The regulator/rectifier should have five wires, three for the alternator stator (possibly all yellow), and the other two might be black and red.
Hi Thanks for the…
Hi
Thanks for the responses. I have added two photos.
At the alternator end you should see two connectors, the cables to the left go to the old alternator (2 wire) on the right each connector has a pair of cables almost like it has been doubled up for some reason, is this a spare cable or two cables required to carry the current. Do I need both or can I split them to give me the third wire for the 3 phase alternator.
The regulator end photo shows the spade connector with a pair of wires attached this is the other end of the cable pair.
Mark
Two or three wires
Hi Mark
Have you bought a new regulator/rectifier to go with your three phase stator? You must have a three phase regulator. I think you are trying to connect your old two wire regulator? or have I missed some detail?
Norm
Hi Norm Yes I have bought a…
Hi Norm
Yes I have bought a 3 phase regulator. The old single phase system use less cables then the new system so I need to provide an additional cable from the regulator to the alternator. What I am trying to find out is if I can split the existing wires as these seem to be provided in pairs between regulator and alternator. If not then what grade of cable do I need to use for the additional 3rd wire.
Mark
Sounds a bit like the…
Sounds a bit like the previous owner rewired and decided to use twin core for each alternator lead. I used a doubled up wire to connect battery to earth because I didn't have a big enough single. Since it sounds like you have four wires to do the job of three you should be OK but only if the wire size is big enough to carry the current.
Your photos
Your photo 1 shows the old two wire alternator connected to the wiring harness
Your photo 2 shows the wiring harness to the original plate rectifier.
You need to study the wiring harness diagram, understand where all the relevant wires go and see what wiring can be reused.
A photo of your new components would be helpful.
fitting a 3 phase alternator and a modern Reg/rectifier tidies up the wiring somewhat as actually there are less wires involved to fewer components I.E. two components to connect as against four with the original system (alternator, rectifier, and the two zeners)
Cables
Thanks Mark, I now understand - you have shown the old two cables for alternator and rectifier, but have a three wire stator and regulator you want to fit.
I think the reason you see pairs is because there will have been two pairs (WG and GY?) connecting to the alternator and then splitting to the old rectifier and zener diodes. We need to check Mark that the zener diodes have already been removed by a previous owner and a COMBINED regulator/rectifier fitted. Or, if the zeners are still fitted to the footrest plates then you need to do some more substantial rewiring - essentially three new cables connecting alternator to new three phase regulator (can be yellow), new regulator earth (red) and live feed (brown/blue) connecting to a fuse and then the battery, and remove the old zeners and rectifier. You also need to work out where to mount the regulator.
Cables are normally rated in cross sectional area, which is not simple to visualise. If you cut away the insulation from an end then a 1.2mm diameter (1mm sq area) copper cable bunch is about 16amp (lights, etc.), 1.7mm (2.0mm sq) is 25amp and 2.1mm (3.0mm sq) is 33amp. The 1.7mm diameter will be enough for each of the three phases, while the 2.1mm diameter is best for connecting the regulator to battery, earth and then fused at 25amp.
I have rewired a few bikes but I am only an amateur and anyone else is welcome to have their say.
First, understand what your…
First, understand what your new system will make redundant, you'll be surprised how many connect a modern rectifier regulator and still leave the zener connected.
Once you have established the above then wiring in the new system will be easy. If the stator is a new Wassel item it will not easily fit a MK3, the old LAP version fitted nicely.
You might need to space it out a bit, but check the outer chaincase will fit. If the stator fails Wassel will not warranty it when used on a MK3.
Using a RM23 stator, mosfet rectifier and BSM, makes the 3 phase upgrade redundant these days. With Tri Spark ignition it will start with the battery disconnected and no blue capacitor either. The BSM shows green on tickover, the old rectifier in the same setup could not even do that. It makes efficient use of what the RM23 stator outputs, and keeps a 14Ahr battery well topped up.
Poor charge
I have a 1969 MK1. As I ride mainly on back roads around 40ish I'm having trouble keeping the battery changed. I was thinking of a three phase Alternator and Reg/Rectifier. If I went with the RM23 would I also have to change the rotor? I've not measured mine yet. Also forgige my ignorance whats a BSM? Tim K.
The rotor should be ok,…
The rotor should be ok, check it has not lost its magnetism. Is your battery knackered? how old is it? Even if your just toddling about the battery should be getting charged. A quick check, When you rev the engine up from tick over does the headlight get brighter? If so what revs does that happen? How old is the wiring? 55 yr old wiring and connectors will be well past there best by now. BSM = Battery Status monitor A very useful bit of kit, Al Osborn sells them
Poor Charge
Thanks for that. I did retire the bike a few years ago and a new battery. But having a number of bikes I have trouble keeping the the batteries charged. I fitted a digital volt meter instead of the amp meter. It does not seem to charge under 2000revs. I rewired it as standard with the Zenor and solid state rectifier. I left out the Capacitor as it had a new battery at the time . I have found a new Wassel Reg/Rec in my drawer so I'll fit that at the weekend , I'm not sure if I still have the Capasitor . Thanks again. Tim K.
Nearly right
The cables in a traditional Commando loom are 8.75A (call it 9A) 14/030. You can use 'modern' thin-wall which says it will carry more current but in fact it carries the same current but the thin wall runs warmer hence does not melt as soon as the 9A cable does.
The two wire we see here are to the Zeners on a MKIII as the Zeners are on the AC ie alternator side of the rectifier. Yes it would be ok to split one pair out to get three wires BUT do make sure you spilt out both end of the same wire. Also running three new wires from the alt. to the reg. would be a better job.
Any further questions give me a call 01953 884681
Thanks Alan That confirms…
Thanks Alan
That confirms my original thoughts, I have split one of the pairs at both ends and it all appears to be working fine.
Mark
The latest 3 phase stators…
The latest 3 phase stators from Lucas don't fit a MK3, you'll need to make spacers and / or remove some of the encapsulation material. Wassell will not warranty it either as it was not an original aprt on a MK3.
The latest 3ph Lucas stators…
The latest 3ph Lucas stators do fit the MK3, But you have to address the stator carrier as the Alloy mounts are too bulbous. Using spacers etc will put the stator out of alignment with the rotor. The photos show where metal has to be removed to get the stator to fit, Three of the reduced hex 5/16 nuts (06 2692) makes it easy to fasten the stator up. Don't be tempted to remove any of the potting compound, The wire inside can be very close to the surface.
Ashley, both yourself an Al were answering a post almost 5 yrs old
The definitive answer -…
The definitive answer - thank you Peter.
I had seen Ashley's comment above but a search on the issue was rather inconclusive with some people suggesting trimming the potting compound - a bad idea as you have noted.
Lots of good/poor information
All the original cables on our bikes are rated at 9AMPS ie it is called 1mm (but you can't measure it) I sell this and I even started the Battery Status Monitor BSM. ALL our rotors are the same since the mid 1960s ie 74 mm dia 19mm bore. if they are old they do loose magnetism, so a new rotor might be enough to get your alternator back into good working order. The MKIII had a high output single phase unit with two Zener diodes (on the Z plates) and a very odd half bridge rectifier-see my web site.
The thread might be 5 years…
The thread might be 5 years old, but it is still something that crops up. The RM23 works just fine if you use a modern rectifier / regulator, charge warning light / battery status monitor and LED bulbs which are legal to use on motorcycles. The MOT regulations for motorcycles no longer mentions bulb but 'light source' which must cast a beam that meets the requirement, the light source can be anything.
I used the above set up and have proven many times that even when starting the MK3 on the starter the BSM shows green after a couple of minutes. The last 14 amp battery I had fitted lasted 6 years with this set also, it would not have lasted if the charge was insufficient.
There are Lucas own testing results that show the output of both, and it was not enough to convince me it was a worthwhile upgrade. Better efficiency can be had by maintaining the harness and charging circuit to reduce losses.
There is absolutely no need to fit a 3 phase stator to a MK3.
Well the OP needed a new…
Well the OP needed a new stator and, if you are going to replace the stator plus fit "a modern rectifier / regulator, charge warning light / battery status monitor" as you suggest, then they might as well go 3-phase.
However I do agree that, given a working RM23, the value of moving to 3-phase depends very much on how the bike is used.
Some numbers are always helpful and here are mine from a Mk3 with the original RM23(?) stator, new rotor, modern (square block) rectifier, original zeners and a Yuasa 14Ah battery. The bike is fitted with a voltmeter connected to the ignition switch and readings were taken on the road.
The power draw is: ignition 3.25A (Rita AB11) + lights(dip) 5.75A (H4 55/60W bulb, 5W pilot, 5W tail, 2x2W instrument illumination). Total 9A.
The 1975 NVT brochure (the one with a Trident alongside various Commandos https://www.classicbike.biz/Norton/Brochures/1970/75PowerChoiceNortonTriumph.pdf) gives the alternator output as 150W = 12.5A.
Lucas rated alternator output at 6,000+ rpm and claimed that 75% of the maximum was delivered at 2,400rpm which in this case would be 9.3A..
At 2,500rpm voltmeter reads 12.5V, i.e. break even. 2,500rpm = 40mph.
At 3,000rpm voltmeter reads 13.5V so the battery is charging.
At 4,000rpm and above the voltmeter reads 14.5V so the battery is charging well and the zeners are dumping any excess. 4,000rpm = 64mph.
Conclusion:
10 minutes on a dual carriageway will restore the battery after a start (assuming your bike is a good starter).
When driving in a 30 limit or waiting at lights, turning the headlight off might be advisable.
If you mostly drive in town, at night or make frequent stops you probably need a high-output 3-phase alternator (or get used to using the kickstarter again). Conversely, if you keep the battery topped up at home then an original Mk3 alternator will deliver all the power you need for Sunday afternoon runs out to a country inn.
Edit:
I've updated the alternator output above to the 150W stated by NVT for the Mk3 Commando.
The, original, alternator stator on my bike has p/n 47239A and date 5 75. The part number given for the currently available RM23 is 47239 with an output of 180W (=15A) - https://www.nortonownersclub.org/support/technical-support-electrical/lucas-rm23-alternator
(Some retailers claim 16A = 192W).
Is it possible that there are different versions of RM23 and the 'A' indicates a lower output stator fitted to the Mk3 Commando?
Anyway, although the returns diminish, a 15A alternator will have a higher output than a 12.5A one down the rev range so you can expect better charging at lower speeds - at the risk of melting the zeners at sustained high speed. If the figure for the currently available RM23 is correct then it would be a plug 'n play swap for a failed original Mk3 stator and should perform better.
Keep it straight.
HIGH OUTPUT 3 PHASE is mentioned above. in fact the Higher output 3 phase has the same output as the RM23 (High output Single phase as MKIII) with regard to maximum power. There was a Medium output 3 phase used on Triumphs in the early 80s (47252 if you want to know).
But no 3phase was ever fitted to any Norton so another 'raspberry' to the originality freaks.
The advantage of 3-phase is…
The advantage of 3-phase is generating more current at lower rpm - useful now we drive with the headlight on.
The lower output RM24 claims to produce 10.5A https://rexs-speedshop.com/product/genuine-lucas-150-watt-rm24-3-wire-stator-lu47252/ (other suppliers are available), i.e. the same as the RM21 fitted to pre-Mk3 Commandos, and makes a good, straightforward replacement for all non-electric start bikes.
You can simply copy the T140 implementation and replace the rectifier with a standard, off-the-shelf 3-phase one: https://uk.rs-online.com/web/p/bridge-rectifiers/3953216. Just add an additional wire from the alternator to the rectifier; everything else is standard Commando, zener and all.
Exactly
What Stan says above is exactly what Triumphs did, fitted a 150W alternator and used a 100W zener as the regulator!!! How can this be you ask? the ignition draws some 20W and the battery charging takes a similar so we use up 40W at least, losses in the wiring makes the 150W 3 phase usable with the 100W zener. By the way I have the 3 phase rectifier for sale.
By the way what is 'Genuine Lucas' ? Lucas as a company failed (along side the British Motorcycle industry) in the mid 80s, the name is used by the Wassell empire.
Seems some are still using…
Seems some are still using zeners with modern rectifier regulators, not sure why as there is no need. As for a 3 phase generating more current at lower revs than a RM23 is somewhat of a red herring. I get 14.3v at the battery at tickover from a cold start using an RM23, that alone suggests that the current and voltage thus the power being generated is more than adequate. This on a bike that used a Chinese sprag for 6 years and still working fine.
The extra hassle to fit it to a MK3 for no extra return is not worth it. The RM23 is more than adequate for the MK3 with electric start, so massively adequate for the pre MK3, even with an Alton kit. After 30 years of MK3 ownership, and 10 years in the trade do you not think I would have fitting one and be singing it praises it was any better than the RM23.
If you are going to replace…
If you are going to replace the rectifier and zeners, I don't see any hassle in running one additional wire from alternator to 'black box'.
Anyway Ashley, while we have your attention, can you shed any light on the Lucas stator part number 47239A? And the NVT brochure statement that the Mk3 has a 150W alternator (as detailed above)?
Does your bike have the original Lucas stator from the 70s or is it a 'new' Lucas (Wassel) RM23 stator? Do you happen to recall the part number stamped on it?
Lucas 47239A stator from crash damaged Mk3 I bought in 1976 (same p/n as the one documented above):
When i bought my Mk3 it had…
When i bought my Mk3 it had a 3ph stator fitted and along with a box of 'spares' These would be better called 'Duds' This lot included a sparx stator without the lead, it had broken off next to the potting compound. If that sparx stator had been fitted to my Mk3 earlier in its life it would mean Mitzi is now on her third stator at least, maybe more.
One of my pet gripes is that the Lucas (original and later ones) used insulating sleeving that hardens in the primary case, (the hot oil leaches the plastisizer out of the sleeving) it then cracks, lets the hot oil get to the green yellow and green white wires and the same happens, they crack and now you have bare copper wire showing. The rubber grommet in the primary case goes as hard as concrete as well, makes it a bit of a juggling match when removing/replacing the primary drive, trying not to flex this lot too much. The photo is a spare stator with the lead repaired and clipped in place.
My usual trick when removing a well used stator from a bike is to pour a kettle full of hot water over the inner primary case, you can then wiggle the lead and grommet out as they are now soft. A hot air gun works as well but you have to be careful as overheating the wires is easy done.
Use a new grommet when refitting the stator.
Fitting one additional wire…
Fitting one additional wire is no hassle if the new style stators were a straight swap mechanically for the RM23. The old versions, usually the old brown LAP version would fit straight on, but the new Wassell Lucas ones don't. Wassell are new to the Lucas trademark, prior to them using in recent years it was LAP who gained the Lucas tooling but not the right to use the trademark I believe. My bike has been through several stators over the years, but I do have the drawing for the stator. They were fitted with a 2 wire high output stator, which was introduced in Jan '74.
The MK3 Ultimate Ride brochure says high output as above, which all ties in nicely with the MK3 factory build book. A lot was carried over from one publication to another, just like the oil capacity for the fork leg.
Considering we have a huge number of Commando's using Alton kits with 150W alternators, the 3 phase stator argument has been pretty well put to bed. Many using the Alton kit use a battery which has a little bit more capacity than a MK3 uses and it all works just fine.
Most would be better off reducing the electrical losses in their wiring than fitting a 3 phase stator.
I agree, get the rest of the…
I agree, get the rest of the wiring up to scratch and the std stator copes just fine. Problems arise nowadays with the increased current draw from accessories added (sat nav, phone, extra lights etc) Granted using Led Lights can reduce the current draw but that can give rise to other problems.
If you ride all year round, the use of heated clothing is a big current draw and you will want the highest output possible, along with a suitable rec/reg
Grant Tiller has a load of information on his website, well worth a read.
Can you take a photo of the alternator, reg/rec and wires inbetween. I,m struggling to understand your description!
