Pistons and compression ratios
When I built my 30's Inter engine a couple of years ago I used an ES2 piston, partly to soften the engine and make it more useable for everyday runs, and partly because it was what was readily available. I think this gives me a compression ratio of about 7:1, however I can now get a propper pre-war racinginter piston with a compression ratio of about 9.5:1.
As I now have my '51 ES2 on the road as wellI am wondering why I want an Inter that also goes like an ES2.
Would this piston be too high a ratio for road use with modern fuels?(I know it has Ethanol in itblah blah blah, this is not a thread on fuels!) I can put a compression plate under it to lower it a bit. I know that its not just a case of changing the piston; balance factors, carburation, valve and ignition timing etc will probably all need tweaking but I'm seriously tempted to have a go and see if I can get a bit more out of the engine.
What set upare other people with Manxes and Inters running?
Andy
I know nothing about Norton singles, but i do run a high compression hot cammed single. Its great for fast "A" roads and the Isle of Man. Its also a bit of a grouch to kick start without a valve lifter and I would happily swap it for a soft single for those club runs in the back lanes. Sounds like you already have a good compromise.
I'm lucky enough to have more than 1 bike. The other 2 are ideal for club runs, fast A roads are kinda what I'm aiming for with this one. Just outa interest, what is your single?
Hi Andy, Ducati 250 Mark3 NC with Mach1 spec motor ported ,40 mm inlet, F1 cam best power 9500/10000rpm. Ton up moped!.
The shop I work in does a lot of work on old Jags and Alfas with a very similar combustion chamber to the Inter. Our customers' experience seems to put 9.5:1 at about the max on pump gas. Get some 110 octane race gas and all bets are off.
In the 1930s, 7:1 was considered pretty high compression. There is a lot more to power output than compression ratio. An Inter on 7:1 should go rather faster than an ES2. 9.5:1 is a bit high for present day petrol. If it were up to me, I would stick to the 7:1 and accept a better-mannered engine and avoid the possibilities of pinking and detonation,known to be detrimental to for the engine's health.
Ignoring the ethanol distraction (several fuels, in the 30's, contained this), modern premium unleaded petrol is of a higher octane rating than normal pump fuel obtainable before the mid 50's. Probably, anything over 9.5/1 would be excessive, but, possibly with slightly retarded ignition, there should be no problems. After all, I don't suppose you are going to ride all day at race speed.
Unless you are sure of a perfect bottom end and are prepared to chance a blow up with loss of case/barrel i would stop at 8 to 1. Is it a 350 or 500?. In any case its a very old gentleman and should be taking it easy in retirement! ,just like me.(not).
Its a 500 and the bottom end is good (was all new when I built the engine 2 years ago). I may well leave it as it is, but am just interested in what other people with inters and manxes run and what I could get out of mine reasonably safely.
Andy
Andy I run a'37 Plunger manx ( Long stroke magnesium), no kickstart. 9.5:1. Its been in this running condition for many miles, with cracksin mudguards, tanks,seat pan(yes it has a full length seat) and frame (sorted witha replacement at one point) displaying itshard use. Itstarts on rollers and is fine once warmed forstarts on general runs as long as you pay attention to where you park. Butwhen you ride it.... itslike nothing else, smooth, fast,a bit wobbly compared to a rigid but stunning performance forsuch an old one.... Ridden asintended,kept like they use to be; fettle before failure, no more.Always use best quality fuel available and keeep the oilclean, the restistestement to your preparation.
Cheers Jon
Hi Jon
My engine is a '36 manx spec one with the all alloy engine and the bronze skull in the cylinder head so slightly earlier than yours. I might have a go at it at some point but I've just stripped my ES2 and found a few more problems with that than I had anticipated so that has to take priority and the Inter is going to have to wait for another time, at least that one runs!
Thanks for the replies, is there anyone else out there running their Manx or Inter on the road?
Andy
Hi Andy
I run my !936 350 Inter on the road in full touring trim. It has an iron head anda cr of just over 8:1and I usestandard pump fuel. I havealso added a cartridge oil filterwhich is fitted beneath the toolbox and use standard 20/50 oil.I have been running the bike in this guise since 1986. An earlier thread was talking about using a TT carb on the road which lacks a tickover facility. I find that with the throttle friction screw set so the throttle doesn't automatically close I can normally set a reasonably steady tickover when I stop. For a ridgid bike I find her quite comfortable andgood for long distance riding apart from the oil it leaks, but it stops me worrying about the back end of the bike rusting! As a comparison I also have a WD 16h and the difference is like chalk and cheese, but it is great for thrashing over shorter distances.
Nick
