Job done , a little tricky to identify the condenser leads and unsolder twist together solder and sleeve with shrink wrap . Easy cap fitting needed a screw to be shortened. Bearings re shimmed and pickups carefully cleaned of internal corrosion. . Testing shows a better spark than before , time to fit to bike and check for timing variance between cylinders.
