Hi can anyone help me by posting a picture of the underside of a lightweight seat, preferably a standard, my seat looks right right from the top but not the bottom, its either a homemade seat, a delux converted to a standard or one from another bike altogether. As it is currently made it has a big gap between the tank and seat which I want to correct. This isnt a concours bike, so I only want it to look right.
Dan
Attachments 001.0.JPG 004.0.JPG technicalHello Dan, Looks like ther…
Picture of Jubilee seat At…
Attachments jubilee-standard-jpg- Log in to post comments
Picture of a De Luxe seat.…
Attachments p2150001-jpg- Log in to post comments
Hi Dan, Some more pictures…
Hi Dan,
Some more pictures to show difference in rear mountings on the frame. This is the Standard Frame mounting.
Patrick
Attachments p2150001-2-jpg- Log in to post comments
And this is the De Luxe At…
Attachments p2150002-2-jpg- Log in to post comments
This is the Yamton and the…
This is the Yamton and theres a few more bikes under the blankets including the Fireblade - I hope.
Attachments p2150004-2-jpg- Log in to post comments
Previously patrick_mullen…
Same as my De Lux seat
Thanks Patrick, I think yo…
Thanks Patrick, I think you are right about the lightweight forum! My seat doesnt have a dent for the rear mudguard so I am thinking that it was a seat made for a delux that has been adapted fpr a standard, I found some mig wire on one of the welds which is a bit of a give away!
Thanks for the pics that gives me the confidence to sort mine. I like the Yamton!
My next problem is chosing a colour scheme!
Dan
Hi just read the message m…
Hi just read the message my standard navi also has a gap between seat and tank I thought this was normal. It fits on two prongs at front and slots into shock mounts at back.
Hi Keith, Your seat mounti…
Hi Keith,
Your seat mountings sound right enough so maybe some variation in fitting is normal. I have just checked my two bikes and they are slightly different to each other.
On the De Luxe Navigator (1961) I can get my fingers easily between the tank and seat - viewed from the top. On the Standard model the fit is a little bit closer but doesn't quite touch the tank . Viewed from the side both seats fit fairly tight to the tank without a noticeable gap.
Patrick
Theearly DLseat is differe…
Theearly DLseat is different to all these having the addition of "Terry" type spring clips and no rear fastener.(just for the record).The spring clips are availiable from the club and alsofit the other early bigger DL machines.I notice that the club has had some rear end supporting frames made, So now someone can build a 650DL,and there will be at least one to see.
Hello Robert, Do you know…
Hello Robert,
Do you know if the rear enclosure is the same for the big twins as for the Lightweights? The side panels are a bit different around the leading edge but they do look pretty similar in appearance. All DL panelwork is now very scarce as people used to throw it away. It was 'bad for the image' in it's day even if it was a very practical idea.
Somehow the 650 will alway look it's best with a race seat, clip-ons,twin chrome clocks and twin silencers!. Fifty odd years ago the 650SS was a legend - a bit like owning your own space ship.. Or am I just showing my age?
Patrick
The rear enclosure is the…
The rear enclosure is the same pressing for the 250 to 650. Perhaps drilled differently ?, The side panels are not interchangeable. I have a spare rear end and dommy rhs side panel.The reason the rear ends are the same is because it cost too much to change the press moulds so they changed the featherbed frame instead and we have a slimline thanks to this,nothing to do with making the bike morecomfortable (which was needed),this was just smoke and mirrors.I still think that a 650 DL would be a fantastic exhibit ( the only one left in the world).
Hi Robert, Thanks for the…
Hi Robert,
Thanks for the useful information on the rear enclosures. Good luck with your 650 De Luxe project.It will certainly be unique and you can truthfully say that 650SS's (real or replicas) are now too common. A bit like BSA Gold Stars - there are now more Gold Stars than B31s!
Patrick
Hello Dan,
Looks like there's only you and me who read any of the Lightweight messages.
Your seat is strange - it's a mixture of the De Luxe and the Standard seat but it looks wrong around the front as well.
My guess is that it started life as a De Luxe seat. Someone has then cut off the rear fixing bracket (which had a dzus fastener) and bolted on the brackets to make it fit to the rear suspension bolts.The original De Luxe mounting is still there as well. In the picture your brackets are at a different angle to mine. But it also looks odd around the front of the seat. There are two fixing tangs on the frame which engage in two rubbers clips on the front underside of the seat.
All my bikes are tuckd up at the moment under loads of blankets at the back of the garage so I can't get to them easily without shifting various vehicles. But I have managed to get the seat of the 1960 Jubilee and the 1961 Navigator De Luxe was at the other end of the garage so I could get photos of that.
Now lets see if we can work out how to attach them. I'll do some bike photos some day soon when they reappear from hibernation. It's Irish winter weather here at the moment.
Good luck with the project.
Patrick
Attachments p1200004-jpg
