Whats the best plugs, ht leads and plug caps for a 1959 Jubilee. 6v electrics at the moment, will convert to 12v later.
John
I get copper wire cored Ht…
John
I get copper wire cored Ht from my local car shop and Ngk plug caps which don't look too modern . You can still get Lodge or KLG plugs if you like traditional . Otherwise pukka NGK (not cheap fakes!) are good and give a slightly better heat range ,but like all modern plugs won't tolerate rich /sooty mixtures and still always be servicable after cleaning.
