atlas chainguard
chainguard bolt fell off, seems to be a bad design,just a bolt and loose nut? is this std? the old 99 has captive nuts fixed to the back of the guard ,much easier to keep tight.
Hello Robert well you now need to clean off the paint work and weld a captive nut on your chain guard bracket and then re-paint, yours anna j
Hi Anna, Its a chrome one so no welding, will probably rivet a captive nut box on the back ,if there is enough room.
