So...no Model 18...but a model 7 instead!
Hi everybody
I now have given up on ever getting my hands on the model 18 I have been waiting for (lack of registration papers and a non caring seller) - thus last month I bought a non-running ES2.
Yesterday a 1954 Model 7 in running and sober condition came up for sale (at 3700 £), and now I am dual Norton owner.
It has the aluminium head, right petrol tank and looks the part. It sounds a bit off though due to high compression pistons. The original seat is also present.
Now I hope to create a more lively branch of the NOC here in Denmark, so we can have some more local scandinavian meetings.
Drive safely
Niels
182475007_906_1024_0_0_0_0_2-jpg
Very nice,how high compression?, the alloy head may cope as its one ratio below the later heads,you can always fit a plate under the barrels. Interesting building behind,raised above ground,whats that about?.
It's the sellers building but I think it has to do with dropped/settled ground underneath, so it looks like they are leveling out the house while building a new foundation.
I haven't measured the compression yet but I also thought about raising the barrel with a plate. It is on it's last set of piston sizes so I will look at it when it needs a rebore and hence linings.
The sound doesn't bother me even though it is a bit more rough, and it starts very easily.
Regarding the price, then all classic and veteran bikes are quite cheap over here. Take a look at the following site, then you'll see what I mean.
http://www.veteranposten.dk/search.asp?Produktgruppe=2&SubGroup=3
If its an easy starter its unlikely that the compression is high enough to be a worry. A 10 to 1 piston in my 250 only actually measures around 9 to 1. Pistons nominally 9 to one for a Dommy after 58 will only make 8 to 1 in the earlier alloy head.
Looks like Denmark is the place to go for cheap bikes! We'd better rush as the clock is ticking.......
Previously niels_svane wrote:
Hi everybody
Drive safely
Niels
You say the original seat is present but the one in the photo is not it. That seat is for a plunger or rigid bike. Also the seat springs on the plunger model 7 seat are much longer. Still I would love to ride that bike around just as it is.
The original dual seat is present yes, in a very nice condition. I'll keep the solo seat (from a bmw) on for now as it is really comfortable to ride with, and looks cool.
