          The rubber joint between the engine oil return pipe and the stub from the oil tank has an elbow in it which carrys the feed for the rocker oil pipe. Mine is split.
Can anyone tell me where I can buy another of these rubber pipes?
hi nigel I have been putti…
hi nigel I have been putting together an es2 1946/49; no oil pipes came with my boxs off parts. nobody seems to sell the part you mention. I made up the tee piece with a 10millimeter plumbers micro-bore fitting you have to solder in 3 short lenghts off 10 mm pipe then drill out to take the 5/16 inch pipe; then ,resolder in appropriot pieces of pipe to take the rubber oil pipe I first tried to expand 5/16 pipe to fit directly into the T piece but had no success. WICKS sell micro bore pipe and fittings. hope this helps Steve
