Mainshaft bearing for 1930 Model 20
Hello!
Looking for mainshaft bearings to a Mod.20 1930
Dimension,type.and manufacture if its possible
Thanks for any information
GÃ?ran
Goran,
Try Vintage Bearing Co in Derby as they regularly list these on EBay U.K. but they are not cheap!
regards, Ian
Previously ian_richtsteig wrote:
Goran,
regards, Ian
Thanks.
I have mailed the Vintage Bearings but they don have list older than 1935
so I need the dimension of the bearings to order
Can anyone help?
GÃ?ran
Goran,
regards, Ian
Thanks.
Can anyone help?
GÃ?ran
Hello Goran,
I checked my spare 1930 Model 20 engine today and have confirmed the bearings you need.
Timing Side: Type MC 22 Single ball (or if available you can substitute a UMC 22). This is the self aligning type. These are metric bearings with the same dimensions of bore 22mm, Outer diameter 50mm and width 17mm.
Drive side: Type RMC 22 single unlipped roller with the same dimensions of 22mm x 50mm x 17mm. This can also be substituted for a single sided lipped roller designation MRC 22. Again with the same dimensions. These are from my Ransome amd Marles and Hoffman bearing catalogues.
Hope this helps
Goran,
regards, Ian
Thanks.
Can anyone help?
GÃ?ran
Hello Goran,
Hope this helps
Thanks!
Now I know what to ask for
GÃ?ran
