1955 ES2 kickstart shaft
It appears impossible to identify the kickstart shaft on my bike - the overall length is 122mm and so far I have been supplied three different shafts and none will fit - either too long or too short!! I cannot finish the bike without a new shaft. Help please - it appears to be the lay down box.
No replies but all sorted - the gearbox is a genuine Norton special GB8 box - no one seems to know anything about them but will now convert it to standard.
Hello,I have a couple of usedkickstart shaft I think is from lay down boxes and they are 133mm overall lenght. If you need one just tell me.
Regards from Svein.
Thanks Svein - how generous! The shaft I needed was 122mm which I have now found is a GB8 gearbox shaft,
Stuart
