000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Clutch Operating Lever Assembly
Good morning all, not for the first time I am confused. My trusty Haynes Manual said to tighten  the clutch operating lever assembly lock ring while holding the clutch operating lever assembly in the correct position. This I have done and the clutch operating lever assembly can be turned [with no end float and no rocking of the assembly]. As I see it, it is deliberately designed to correctly self align when the clutch cable is in use - so no problem.
I have checked at ANIL, and my manual, but there is no spacer which if tightened would prevent the assembly from rotating nor can I see any reason why the assembly should not be allowed to self align. I have read one of our technical notes which said if the assembly is not fitted in line will cause the cable to deform to a "Z" shape and make clutch operating force to rise.
I feel inclined to leave this as it is but your comments would be welcome.
Thanks Roger
Hi Roger. The locking ring should (as the name suggests) lock the clutch operating body in place so that it can’t be rotated left and right. The operating lever should only be able to move in and out by moving along the slot in the clutch op body, i.e. inwards towards the gearbox and outwards away from the gearbox. Once the locking ring is fully tightened, It shouldn’t be possible to rotate the clutch operating body at all. You’re correct in saying that there’s no spacer so I think you may well have a mismatch of parts possibly from a different year/model.
Privacy Policy
