I’m doing some research on my 1967 650SS. I have uncovered the Reynolds frame number near the headstock, I realize it’s a date stamp that Reynolds applied but unable to interpolate it’s meaning, please see attached picture. Any help would be appreciated
I read that as
Hi. I have EXACTLY the same…
Hi. I have EXACTLY the same digits arranged the same way on my 1960 Dommie 99. I can’t guarantee that the frame is original but it seems a real coincidence that our frames, seemingly several years apart, have identical stamping. The frame number on my bike looks original, not ‘re-stamped’.
The mystery deepens!
Tony, in addition to the…
Tony, in addition to the Reynolds date code stamps that we are talking about here there is also a Norton chassis number stamped on the left frame gusset. What is your stamp that Norton applied to the frame? Thanks for your interest by the way.
George, how did you determine that?
Reading it the other way up, you have 06, followed by a line, then a 7. From this, 06 = June, and the 7 is for 67? Thats how I see it anyway.
Do a search on here. Anna Dixon alone has mentioned the date stamp in loads of posts. Many others have too.
Regards,
George.
From my point of view, the …
From my point of view, the ‘7’ is ‘July’ and ‘60’ is ‘1960’. That fits in perfectly for my 1960 Dommie 99. Or maybe it’s not a date code at all - it just seems too much of a coincidence that two bikes that are seven years apart in manufacturing date should have identical number stamps on the head steady lug - perhaps it’s some other sort of code that Renolds used - for example a tube type.
I think that stamp has been…
I think that stamp has been altered . perhaps an earlier frame with a later engine . a close up photo of the frame number and the area around may give up more clues.
frame dates
I have 4 slimlines.
I just checked 3.
Standing on the right side of the bike looking down, they are all from left to right Month/ space/ year (2 digit) My 63 atlas is 5.. 63,
The 66 atlas I had to sand blast get a good clear view and reads 1..66..M the 6"s are sloppy but clear enough to make out.
The 68 atlas is 1..68 with a A upside down partially over the 8
I am surprised with the…
I am surprised with the diversity of opinion, thought that this would be straight forward and universally accept by most.
I don't know the answer and seek it and there appears to be 3 different answers given. To address one, Tony my number reads /06/7/Renyolds stamp. It sounds like yours reads /60/7/Reynolds stamp standing on right side of bike reading from left to right in witch case they are different. Hope we can resolve this little puzzle.
Is it not UK convention to state /day/month/year or in this case would it not be simple /month/year/??
Add to diversity
My model year -68 650SS is stamped, looking from the right side, probably 5 and then 67. Sounds plausible as it was first registered in october -67.
The -59 99 is also read from the right side, probable 4 and then59.
The -59 Manx.is built in March -59 and hard to read. Guess it's 1 59. If read from right side.
Hi William. My number reads:…
<Renolds letters> - 7 - 60
(photo below) which to me reads ‘7-60’ - others may read it as ‘06 -7‘’. I guess it all depends on the direction in which it is read. I prefer to think that they’d use two numbers for the year as that seems to follow convention.
Seven Year Itch
Just picking up on a comment above that two frames had identical numbers stamped on the Headstock but were seven years apart in manufacture.
This would clearly show up in specific features of each frame. The earlier frame would probably have a bolted-in-place gearbox top mounting whereas the later frames had this section welded to the main tubes. The front engine frame lugs (post-1963) were reversed after some early Atlas frames fractured their downtubes.
It strikes me that Reynolds…
It strikes me that Reynolds stamped this in various ways perhaps based on the individual doing the stamping. Sometimes using two numbers for the year and sometimes using 1. I think the following points are consistent.
-the number is always read from standing on the right side of the bike
-the number is always read from left to right
-any number with in the hash marks such as /57/ represents the year or month. In other words there is no carry over from month to year or vice versa if all numbers are with in the hash marks
Do you agree or other wise? Thank you for all your comments.
Manufacturing process.
The number stamping is secondary to the punch press manufacture of the gusset. Being schooled and owner of 3 stamping punch presses, I see the metals edge texture normal to punch press sheering action. It results in only fair results on the punched number clarity. If a gusset is dressed or filed the edge becomes smooth and broader.It also looses the expected sheer pattern. It can be restamped and looses the feeling of factory originality. Based on my 3 frames the factory did not seem to bother dressing the gusset for number clarity purposes.
Letters and Numbers
Many Slimline Owners think that the 'M' found on the headstock refers to the Manxman 650 connection with the Slimline frames. This is not likely as the term Manxman came about well after the first Slimline frame drawings were completed. These were started in 1957 and it is more likely that the 'M' came from the Factory letter year designator as found on the engine crankcases up until 1961. 'M' standing for production year 1957.
Hi William....I got your email regarding Featherbed frame lugs. Perhaps if you repeat the questions on this thread somebody could offer a better / clearer explanation. I have attached a section of the Dominator Service Notes which I noted mentioned some of the same points.
The frame was made in June 1967. Any other takers?
George
