Could someone please confirm if a 1933 International should have a Dolls head gearbox or a Sturmy. I thought the Dolls head didn't come out until 1935. Seems a lot of pictures I've seen of 1933 models have a Dollshead. Many thanks.
Extract from our tab MODELS…
Production Dates.
The Doll's Head was fitted across the range from the 1935 model year (production from late August 1934 onwards). The brochure states "..identical to that used so successfully on our racing machines."
There doesn't seem to have been any suggestion that 'ordinary' Internationals would have been fitted with one before this time.
All gearboxes are numbered though so it should be straightforward to check if it was originally fitted. The huge number of WD Norton boxes available after the war and lack of parts for the earlier type has means that many were upgraded (witness the number of pre-war Inters featuring the wartime WD brass indicator plate).
Thank you Richard. Exactly…
Thank you Richard. Exactly what I thought. It seems more are now fitted with the Dollshead than what they had before. For those years before '35 I mean.
Thanks for that Jonathan…
Thanks for that Jonathan. The reason I asked, although it was more for conformation than anything else , is many more appear to have the Dollshead than the original gearbox fitted. Just thought it was strange that this was the case.
Possibly lots of the Sturmey…
Possibly lots of the Sturmey Archer boxes were replaced by WD boxes when one of the top lugs snapped off.
Extract from our tab MODELS/SINGLE CYLINDER/OVERHEAD CAMSHAFT.
"A Norton manufactured clutch was used from 1934 onwards, and the Norton/Burman gearbox from the following year. "
Its whats written but... I do remember someone saying "its gona be great!" also.
