I wonder if someone could tell me how to tell if you have enough oil in a dolls head gearbox.I have always filled it until oil runs out of the filling plug.Also I seem to have quite a bad leak from the lower,I believe its called quadrant plate. Its where the gear change selector rod fits onto. Any advice would be much appreciated.
Previously nicholas_reeves…
That's odd, Jonathan. The…
That's odd, Jonathan. The WD manual says to fill the four speed box up to the level of the filler. Are there different filler levels on different boxes?
I agree with you David, wh…
I agree with you David, when you can't put any more in, that's the level and what it says in the WD maintenance book. Bet Richard P would confirm that.
Mine used to leak a bit from the sleeve bearing but not so much since replacement.
One day I will get around to changing to a grease made for such gearboxes that turns liquid when hot and solidifies when cool. That will stop the leaks when stood.
For the last 19 years I have been using Classic EP 140, mostly Castrol. (OK with yellow metal)
Previously Neil Wyatt wrot…
1/2 pint is whatitsays in mymanual (1951).I putit in,itdosent leak; I use straight50. Grease is okbut tends to clog up the kickstartpawl ifyouleaveitstand...
Cheers, J
Previously nicholas_reeves wrote:
Nic;do you have a drain plug? Ifso,drain it andfill withtherequired 1/2 pint.Ifyour up to theneck of thefiller you areway toofull. With that amount of oilflailing around i'mnot surpriseditseepsout thechange quadrant bush. Ifyouregulate it to the requiredlevel and itstill leaksits probably theaforementioned bushthat'sworn.Simplereplacement next time your boxisoutandyour good to go.
