Hi there - I need a petrol tap for my Classic. I can only find one for the Commander, which looks similar but it is mounted on the offside - if I fit it to the classic the fuel outlet will point forward, not a big deal but would like correct part.
Anyone know where I can get the correct tap? Was it used on another bike? Steve
Can you post a picture..
Thanks I found one - they…
Thanks I found one - they are almost identical to the vacuum tap on the 80's Kawasaki, need to re-route the fuel pipe a bit but should work fine
Steve
..of what you are looking for? That way it might be identifiable as to whether it was used elsewhere.
George.
