000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
2015 Norton 961 Sport Drain Plug
Looking for a oil drain plug replacement need new one.... original is getting stripped very soft material any suggestions
new Norton owner
This is where I got mine from
Burnett & Hillman: Hydraulic Adaptors fittings & components
'Burnett & Hillman  Hydraulic supplies'  just look on the web.
Your looking for ....'Metric socket head with 3869 seal'. If you type in 'Metric socket head' in the search box it should take you straight to the correct page. Just make sure you order the right size and pitch thread
Michael:
Have you checked with your local dealer for the replacement plug?
It would seem to me to be the place to go to.
Michael:
If you can give me the part number I will check the local sources here in the San Francisco Bay Area.
Privacy Policy
