Please could someone advise me what notch the float needle should be in on a 276 Amal. Top or bottom. 1935 Es2. Many thanks.
Knoch on a ES2
Bearing in mind the range of…
Bearing in mind the range of fittings that you could have I would try both and go for the one that gave the highest float position without causing the carb to flood and drip fuel.
Thank you Anna. That's what…
Thank you Anna. That's what I thought. Just making sure.
One is for the brass float…
One is for the brass float and the other for the new plastic one. Old needles only had the one. The one for the plastic float is the lower one..further down from the top. Old needles only had the upper groove (from my sample of two..)
Hello normally set second down from the top but this depends on the on the needle type of you have yours AnnaJ
