Float needle position. Amal 276.
Please could someone advise me what notch the float needle should be in on a 276 Amal. Top or bottom. 1935 Es2. Many thanks.
Hello normally  set second  down from the top but this depends on the on the needle type of you have yours AnnaJ
Bearing in mind the range of fittings that you could have I would try both and go for the one that gave the highest float position without causing the carb to flood and drip fuel.
One is for the brass float and the other for the new plastic one. Old needles only had the one. The one for the plastic float is the lower one..further down from the top. Old needles only had the upper groove (from my sample of two..)
