Hi I have acquired a Tshaped Battery holder for the bike and I know I need a 6v Battery, can anyone suggest the Battery Make and Model that will fit it?
Norton 16H 1936 Battery 6V
Can you suggest what make of battery and its ref no?
6v Batteries
My bike originally had a Yuasa 6N6-3B-1 standard Lead Acid battery fitted snuggly inside the T-shaped battery box. This battery measured 10cm Wide x 11.5cm High and 6cm Deep.
When I upgraded the electrics to 12v I then purchased an Ultra-Max sealed Lead Acid battery rated at 12v 4.5Ah. This is 9cm W x 10cm H and 7cm D and still easily fits inside the T-Box.
The latter works well but does have spade connectors. Please don't mention this point to Al Oz.
.. very much that you can buy an actual T shaped battery these days. But there are lots of T shaped battery casings that you can slot a modern one into. Some are better quality than others.
