000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Paddock stand, (rear) for mk1.
Does anyone know if it possible to use one on a mk1 as bobbins etc are only available for mk2s. I only have this bike as I,ve been told never to kick my 850 mk 3 again after surgeon removed my bladder , prostate and lymph nodes etc. And yes I will get the starter on the mk 3 working. Many hours and trials. Almost there! But in the meantime as the 961 has no centre stand ?? . Thanks, Roy Jack.
I've always had a paddock stand for my Mk1 961 Sport and would make a reasonable guess they didn't change anything on the swinging arm / rear wheel set up on the Mk2 so likely bobbins are the same , but you'd need to check with Norton to be quite sure. If you get fixed up with the paddock stand don't forget you have to remove the bobbins before riding - I've forgotten a couple of times and got away with it but the clearance with silencers is only 1 or 2 mm !
Thanks. I'll order some bobbins and try. Wonder why all the ones for sale state 2015 on ? Have e-mailed norton on a few subjects but never had a reply? Too busy possibly ! Roy.
From accessnorton forums, it is generally better to ring.    The service  team should know. Jan.
Privacy Policy
