Valve lash caps
I see Paul Norman sells valve stem lash caps.  I'm replacing my valves and guides.  I wonder if caps are worthwhile?  Mine are both dented.  Exhaust more than inlet.  I've no idea of their origin.  New ones will be G&S.  If i am to use caps, valve stems might need shortening, so I'll probably not add them
Valves, seats, stems, rockers all wear or are "cleaned up/ re cut" over time.  Check your midpoint lift against your contact angle.  You may win something back.
