Prewar Es2 camshaft bush part number?
Hi, can anyone please advise the correct part number for the camshaft bushes for a 1934 ES2? Also if possible how much wear is tolerable on these bushes please?
Many thanks in advance
Les
thank you Richard, happy to pay2/6d each !
next question of course is where might I find them?
They're not the same part number as the WD engines for which Russell Motors may well have parts. The pre-'35 timing cover is not the same casting as the later models.
I suspect that it will be a case of carefully removing the old and having a set turned up (unless you have a lathe yourself of course).
