Pre-oil clutch plates?
Hi there.
I am just fitting new pressure plate and friction plates to my 1972 Commando. Should I soak the friction plates in primary drive oil before fitting, or should they go in dry? My Haynes manual doesn't say, but I always used to do it on my old Triumphs.
Also, any recommendations on the best primary oil to use please?
Many thanks,
Brian
Previously Brian Steers wrote:
Hi there.
Many thanks,
Brian
ATF works well In mine.
The clutch plates are designed to run dry with only sufficient oil in the primary chaincase to lubricate the primary chain. I have always used ATF but after some of the chain rollers seperated and on the advice of a friend I am now using 10/40 oil.
Tim
