Noisy Norton!!!!
I have finally tracked down the source of the very loud “ drowning/ whirring noise on my 16h. It is the new half time pinion that came from India. I have tried several timing gears on the exhaust side and they all make the noise when in contact with the half time pinion - it is easy to hear just using the kickstart. I have it fitted with the “dished” concave side inwards - is this correct?
 Thanks again for everyone’s help
Gary
There should be a hard washer behind it. Easy to lose, especially if the shaft is loose.  If so, check recent posts about which way up it goes if you loctite it.
... that you'd fitted an Indian-made pinion? I would steer well clear of anything which is so vital unless I was sure of its provenance. Failure could cause catastrophic damage. There must still be genuine pinions about. Norvil list them although at a pretty hefty price.
