Hi
I want to strip the gearbox down on my 77` Commando 850 MK3 but don`t want to strip the Primary side down, Now I understand that the High gear and shaft I will not be able to touch, but can I still remove the camPlate with that in place as if that will come out I also know that the gear change Quadrant will come out just thinking about that camplate hitting the high gear
Thanks in advance Mo
If you take the selector s…
Thanks I have just strippe…
Thanks I have just stripped the box down so just the high gear is left in and found
that you can`t remove the cam plate as this hit`s into that high gear, the only reason
was so I can get to the cam plate as Neutral was hard to find, if you were in second gear
it would go though neutral into first gear and if you were in first it would go though neutral into second and on the odd time it would hit neutral, I have checked out everything in the outer case and renewed the ratchet plate the pawl and the springs and anything else that was needed last year and still had that same problem, I have checked out that V in the cam plate for the Plunger sits in and yes I renewed the plunger too the only thing I could do is just give that Neutral V a little touch with a file but nothing drastic.... also check out the little raised bump on the cam plate for the neutral switch as the is a MK3, at one time I even backed off the switch so it was not even touching the plate that did not make any difference at all.
so if there is anyone who has come across this problem please let me know before I put it all back together would be great.... it`s been a nightmare as if you come up to a junction or traffic lights the time you have found Neutral it time to go again
You won't be able to file…
You won't be able to file the camplate as it will be hardened. It should not be necessary anyway. Perhaps the spring behind the indexing plunger is weak?
Difficulty finding neutral is usually because the clutch is dragging. Have you stripped the clutch and washed the plates?
I agree with Norman, clutc…
I agree with Norman, clutch dragging is the usual reason for the gear lever "overshooting". I remember many "happy" hours going backwards and forwards between 1st and 2nd till I sorted my Commando out!
The problem will be clutch…
The problem will be clutch related, but there can be many reasons .
I have replaced the spring…
I have replaced the spring and the plunger and that did not work, I stripped the clutch as had to sort out the dreaded sprag clutch bearing along with the crankshaft sprocket and starter gear, I also washed all clutch plates Drum etc thoroughly and replaced clutch drum back bearing and it still do the same, that`s why I have stripped the gearbox down, I replaced all the parts in the outer gearbox case last year and still it do the same, my mate`s 750 has a nice click when it go`s from first to second and Neutral engage with a nice feel to it.... but not on my 77` 850 mk3, I even checked out the cross over shaft including the connector which connects the two shafts where it go`s in the back of the gearbox.....still can`t find what the hell it is.... so very very Frustrating when I keep spending money and it still the same
Hi Mo A few questions to g…
Hi Mo
A few questions to get a better understanding.
Is your clutch very heavy to operate?
Are both the hardened clutch centre and drum notch free?
What friction plates are you using?
Approximately how many miles on your clutch?
What lubricant are you using for the primary drive?
Did you set the wishbone spring up?
Is the gear lever shaft bush in the primary in good condition?
How much lift on you on the diaphragm spring centre when you squeeze the lever?
Katherine Scott
Hi Katherine No I would sa…
Hi Katherine
No I would say its not heavy to operate, and the clutch centre is new clutch is
surflex plates, and the clutch has only done 4000 miles.
I tried using ATF that I did not like so use 20/50 as per many MK3 owners say to use,
Yes the Ratchet spring is set up the right way round and just sits up against the pawl
and both the bush`s in the outer and inner gearbox are fine along with the bush in the Primary, also the lift on the clutch diaphragm is good as it release all the plates no problem,
Thanks Mo
Previously maurice_cloud w…
Previously maurice_cloud wrote:
Hi Katherine
Thanks Mo
Hi Mo
I have been helping a friend with his 77 MK3, like you (all of us) he had replaced all suspect parts.
There should be minimal clearance between the pawl and the wishbone spring, this requires a little bending of the spring to get it right. I turned up a small spacer to fit on the end of the gearbox cross over shaft primary side to take out most of the end float(you can test with washers). I have shimmed out the excess end float on the lay shaft using 750 iso shims. We use bronze plates from AN, with one original 2mm steel replaced with one of RGM's 3mm steel plates. Currently experimenting with 10w 40 semi synthetic in the primary case with no adverse effects so far. Finding neutral and general gear selection much improved.
Good Luck
Katherine Scott
Hi Mo, Have you disturbed…
Hi Mo,
Have you disturbed the adjustment of the neutral switch at all?
If this is set too 'tight' (i.e. screwed in too far) it will cause considerable drag on the camplate.
Other than that, as has already been mentioned, I have found that setting the pawl spring is paramount. There is basically only one correct setting. Too close/touching the pawl will cause binding and/or mis-selection of gears. Too loose and you'll have lots of free play in the gear lever.
It took me many attempts at re-shaping the spring when I fitted a new one as part of a full gearbox rebuild. During the process I tried three new springs - all were a slightly different shape, and none of them fitted correctly 'out of the packet.'
[url= http://zupimages.net…
[url=http://zupimages.net/viewer.php?id=18/04/0zzp.jpg][img]https://zupimages.net/up/18/04/0zzp.jpg[/img][/url]
Thanks to everyone for the…
Thanks to everyone for the input.
I am going to double check the spring as to the arms and how close to the pawl they are
and adjust the if need be,
thanks Katherine I have just got some rear Isolastic shims from AN with all the rest of the parts ordered so will shim that out between .005" to .010" end float as when last checked it was around .035" so I will do that just waiting for AN with my other parts which will take about two weeks then I can put the gearbox back together again,
I am not going to take apart the Primary again till I see how the gearbox acts after all that I am doing to it so the Surflex Fibre plates and the oil I will keep as is till then,
I have done a Mod on the clutch push rod as I know you can buy a Nut with a O ring in it to go on the clutch centre but not going to pay £29 for a nut to try and stop any gearbox oil going though to contaminate the clutch and it`s plates, so I got a 6mm Dia silver steel rod and hardened each end and put in a recess to take an o ring which might help stop some of the oil traveling across to the clutch side don`t think it will stop all...so you never know it might help
Previously allan_walker wr…
Previously allan_walker wrote:
Hi Mo,
Hi Allan
I am now also putting a new Neutral switch in and am going to set it up while I have the gearbox apart using my Fluke meter set to when the switch hit`s the Neutral button on the cam plate it will sound and I can lock it off with the lock nut and I will know then that it is set to the best it can be,
Allan is spot-on with his…
Allan is spot-on with his reference to the neutral switch. It can bind to the extent of leaving a track across the nose of the switch and this provides a sort of anti-detent for neutral.
You may be surprised just how little of the switch is screwed in.
I really thought that the cam plate could be removed if the box was empty except for sleeve gear and mainshaft. The dangers of relying on memory !
Hi I have put all the gear…
Hi
I have put all the gears back in until you said about the track across the the dimple on the cam plate for the Neutral to push in the switch so I have taken the gears back and looked at the profile on that dimple and it did not have a nice finish on it and there was a small track on it like you said, so I have re-profiled it so when the head of the switch come up to it now has a better run over it, the I have set it up so the switch only just work when it is in Neutral allowing for heat expansion and it run over the dimple a lot better,
so I hope in a week or two when I get the rest of my gearbox parts I can put it back together and hope it is better
Oh I did check the out case with the spring and it fitting nice up to the pawl so that`s good
If you take the selector shaft out (it has 2 flats on the outer end) with the selector forks I think the camplate can then be removed but it's a while since I've done that.
