Lower fork butchery
I am trying to make sense of a leak on the LH fork. On inspection there is no way of putting a box spanner up the leg as the manual shows. I guess someone in the past has tried to plug it up with something. So I am trying to get the fork out.
My problem is that I have undone the the main fork tube retainer and filler chrome nut on the top of the fork and it appears that I have about 15mm of thread showing.It turns and turns but does not come out any idea what I am doing wrong?
If wheel and mudguard have been removed then it is probably hanging under its own weight. You'll need to push the slider up, bringing top nut and damper rod to a position where you can separate them.
Thanks to Richard I have now got the fork out, its easy if you know how >>> now I do.
As suspected the fork bottom has been welded closed in an attempt to give some support to the snapped and missing part of the pinch bolt. Cant see a way of mending it so looks like a new fork bottom is required anyone got one for sale?
capture-png
Good grief! I hope the rest of the bike is not like that. I mean, that's not even a good bodge. John
Graham. You are unlikely to find a good used one. Cracking through overtightening the pinch bolt is a common weakness, and any 50 year old part is likely to be weakened by now, so you could put good money after bad. I bought a new upgraded one, beefier round the nether regions, which gives piece of mind.
