Can anyone advise me of where I can pick up grease nipple to fit the thread on my 1949 ES2? one has dropped out and the only replacements I can find are metric threads and not cycle thread ( as I believe these are) Any comments , particularly amusing , will be greatfully received. Cheers Glenn
The nipples weren't a spe…
Richard - how about the ol…
My local agricultural marc…
My local agricultural marchants sells packets of both metric and imperial grease nipples. The do have the blob on the end but they do come in a variety of thread sizes including the bigger ones you need. Don't know of a source of nipples for the old brass guns though. Yes, the cloth over the nipple works quite well, a tip from my Dad.
I know of no sources for t…
I know of no sources for the old 'low pressure' nipples. Nortons used straight and 45? around the headstocks of girder-equipped bikes.
They turn up occasionally on e-Bay, or at jumbles (Beaulieu is the best bet).
I have no difficulty pushing grease through my forks using a modern gun. It slots over the original nipples without any problem and I keep it pushed on.
If a speedo bracket is fitted then the top two on the girder forks screw into special reduction nuts. I don't know what they did on the panel tank models.
I wanted the original styl…
I wanted the original style for my M77 rebuild a few years back, found them on ebay at the time. Fairly certain they were 2BA thread size. I will try to locate the extra stock I bought back then & verify.
2BA has an outside diameter of .185 inches & a thread pitch of 31.4 threads per inch (TPI).
Skip Brolund
Hi I've just ordered some…
Hi I've just ordered some from Racing Norton.com they have the type you require.
Tim.
Thanks.. but the ones i am…
David, on bikes with a for…
David, on bikes with a fork-mounted speedo, the brackets are held by adapters (part no. 3968) :-
The small nipples (part no. 3967) appear to be threaded 3/16" x 32tpi - 1/4" across flats.
They seem to be available but the minimum quantity that I've found listed is 5000 !
http://www.kingfisherlubrication.co.uk/catalogue/greasenipples/798_PushType316X32BsfPushType.html
The rest of the nipples on the forks with the exception of lower head race are of the 45? type. All the other chassis nipples seem to be listed as 1/4"
I have no difficulty getting grease into any of these with a high pressure gun, with the exception of the hollow clevis pins for the rebound springs, and they're not really proper nipples.
www.thenippleshop.co.uk ha…
www.thenippleshop.co.uk has a good selection at reasonable prices
Thanks to all of your comm…
Thanks to all of your comments. I will investigate the source above, as its only one I need! cheers Glenn
Previously eugene_brolund…
Skip Brolund
thanks Skip, these sound like the same as mine. I only need one. DO you have a spare one I could buy from you? Thanks Glenn
I will see if I have some…
I will see if I have some left. Here is a 2ba fitting, but with the "blob":
http://www.ebay.com/itm/Rare-Vintage-2BA-Threaded-Bottom-Bracket-Grease-Nipple-/251700950409
or these:
http://velobase.com/ViewComponent.aspx?ID=2b8e9a54-a3d2-458b-9061-a148cac0ddfa&Enum=103
Or, page 164 of the Walridge catalogue:
GREASE NIPPLES British made threads but designed to work with modern grease guns
1/4â BSF Straight L145A $2.911/4â BSF Angled L145B $3.092BA Straight L145C $2.84- Log in to post comments
The nipples weren't a specific cycle / motorcycle part and are normally 1/4" BSF.
If you 'Google' 1/4" BSF Grease Nipples, there are plenty of suppliers.
[IMG]http://i248.photobucket.com/albums/gg164/commando16h/NOC/Tecalemit_zpsuic7lfpz.jpg[/IMG]
