I want to replace the seals on the gearshift and kickstarter lever in the outer cover. Will the kickstarter bush and gearshift bush fall out if I heat up in the oven and knock on to a piece of wood? I suspect the steel kickstarter bush will but what about the copper gearshift bush?
You should be able to repl…
Thanks Karl, That was an e…
Thanks Karl,
That was an easy solution. All done.
Just a note to say that, i…
Just a note to say that, in my experience, the X-rings are indeed superb compared to the original O-rings, but the one on my gearshift did not survive one removal of the outer cover â so forgive me if I'm stating the obvious but get spares before you need them.
You should be able to replace the seal without removing the bushes. I can personally vouch for the "X ring" type over the normal O rings.
