Thanks for all help with stanchions . Have rebuilt forks , master cylinder and caliper . After reassembly I notice the front wheel is off centre between the forksbut cannot see any other way to do it due to the disc . Have I made a mistake ? Its a 1972 commando with standard disc and caliper . Any advice would be appreciated .
Has the front wheel been r…
Previously richard_payne w…
Previously richard_payne wrote:
Has the front wheel been rebuilt ?
Many wheelbulders fail to pull the rim over to the disc side sufficiently. The spokes on that side have to stand almost vertically. It's one of the most common causes of odd steering on rebuilt Commandos.
A talk with a decent wheelbuilder might be the best option.
Thanks for reply . I assum…
Thanks for reply . I assume the wheel has been rebuilt wrongly at some time . There is no offset from hub to rim . Have also noticed lots of comments on the website from previous queries . I will have to find a wheelbuilder who knows what the correct offset should be .Thanks again , Roy
As Richard says, the Comma…
As Richard says, the Commando disc brake wheel has almost no dish on the disc side, this makes it very difficult for the wheel builder to pull the wheel across to that side (whichever side you have the brake fitted) This can result in the wheel builder putting a massive amount of tension in that side spokes to achieve a result. With the tyre and mudguard fitted it is difficult to measure the error. My disc is about 0.010" away from the fork leg, others have more. You can adjust the spacers to a certain extent but the disc touching the fork leg is the limiting factor here.
I bought my 1970 Fastback for £350 in 1975, I spent about £500 many years later changing to disc front end.
Disc brake wheel spokes. 1…
Thanks for detailed reply…
Thanks for detailed reply . I have re-set a wheel with no offset , but I think I will send thisoff for attention! After wanting a commando for so long I realise there is a lot to learn .
