Hi - has anyone found a way of stopping oil leaking from the front right cylinder head stud. I've owned a couple of Mk2 commandos (850) and have never found a way of fixing this problem. The stud in question breaks into the pushrod tunnel and I'm told oil makes its way up the thread and comes out 3 fins above the head gasket. I've got an old police fairing and the oil spreads itself down the inside on the right. I've tried most things (bunging up the hole where it breaks through, using thread-seal. I've even made a special nut with groove for an o-ring) - no success. Any suggestions?
Cheers - John
If it's the dreaded 3rd f…
I am not sure that everybo…
I am not sure that everybody above is singing using the same carol sheet.John is talking about his front barrel studs and Chris the cylinder head. Though both can have oil leak issues due to porosity, cracks or duff threads.
I had an Atlas cylinder head and barrel which both dripped oil from well-known weak ares when pushed hard. The cylinder head leaked from the rear right bolt hole, just behind the plug, due to the thiness of the casting. The barrel problem was due to some bright spark enlarging the two front 5/16" studs up to 3/8".....causing them to break through the pushrod tunnel and so giving the crankcase vapour an alternative exit to the almost useless camshaft breather.
Having visited the Triumph Factory and seen their vacuum resin impregnated cylinder heads I tried the ACME DIY version to try and sort my problems. Strangely it worked for a year and then I sold the bike.
On the cylinder head I de-greased and then heated up the offending area, with a gas torch, until water dripped on it sizzed. I then mixed up some Araldite goo and spread it over the suspect area. The hot metal makes the goo go very runny and then soak into the surface.
The barrels were given a simlar cleansing and heat treatment but this time I spread the goo over the stud threads and inside the barrel stud holes before winding the studs into place. The barrels were laid on their backs so that any excess goo pushed out by the studs stayed near their ends. Any excess was trimmed and wire-brushed away after the barrels had cooled. When the time came for re-fitting the head in place, I used a thin layer of High Temperature Silicon around both sides of the gasket in the pushrod tunnel area and also around the base of the two front studs.
Hi - has anyone found a wa…
Phil - that looks to me as if John is talking about his cylinder head and not about his barrel .....
..... unless he has in some way mounted his barrel on top of his cylinder head.
John wrote................…
John wrote.........................
'The stud in question breaks into the pushrod tunnel and I'm told oil makes its way up the thread and comes out 3 fins above the head gasket.'
Studs breaking into the pushrod tunnels must surely be the two at the front of the barrel. The two front cylinder head studs will only affect the exhaust ports in the head and the other ends are too far away from the pushrod tunnels in the barrel. The rear cylinder head stud is under the inlet valve area and nowhere near the pushrod tunnels.
The oil john mentions is inside the pushrod tunnels. It is passing though the damaged walls of the pushrod tunnels where the bottom ends of the front barrel studs have broken through. It is then leaking upwards past the body of studs until it reaches the nuts. Which are both sitting next to the third fin, top front of his cylinder head.
The attachments may help or you could try reading the DSNs.
750-barrel-jpg
Many thanks for giving thi…
Many thanks for giving this some thought. I'll let you know how I get on.
John
IPreviously Phil Hannam wr…
I to have this problem with the two 5/16 studs breaking into the pushrod tunnels in a 750 Commando engine. I wish my barrels looked as good as the ones in the picture. Mine are on the edge of the pushrod tunnels and the threads break into it.
I have built quite a few Norton twins some for racing and some for the road, the only time I have experienced leaks is with this engine I have with the studs breaking through.
I have Araldited the hole and inside the tunnel. I have also machined the two faces on the cylinder head where the studs come out and made special nuts with big flanges and used alloy washers which has just about sorted the problem.
As the barrels are on std bore I don't want to scrap them. Just crap machinig I suppose at the works.
Happy 2015 riding. Tony
The problem with Norton ba…
The problem with Norton barrels started to get worse when the SS versions of the engine arrived. The SS cylinder heads needed the fatter SS pushrods to cope with the beefier valve springs and these pushrods, in turn, needed bigger tunnels to operate in. This might not have been a problem if the tunnels had been more precisely machined. It is almost impossible to find any two similar barrels (same year & size) that have near identical maching. The quiz picture in the November Roadholder illustrates this point quite well. You tend to feel that Stevie Wonder would have done a far better job if asked.
Apart from Aralditing the studs in place I have seen another desperate repair that seem to have worked. This was cutting the bottom few threads off the studs and then brazing them in place inside the respective tunnels. There is an arc welding rod available for disimilar metals which could probably be used in a similar way. They are very good at joining most other metals to barrel castings. Cleaning up the weld might be a bit time consuming.
Thanks for the ideas. Braz…
Thanks for the ideas. Brazing plugs into the bottoms of the holes seems a bit drastic so I think I'll try the Aralditing idea first.
It's interesting to note that, although there are lots of ideas, only one person (Tony Harris) is brave enough to claim any success saying that all his labours have "just about sorted the problem".
Oh, the joys of British biking! - Thanks again...John
My 73 850 had the oil leak…
My 73 850 had the oil leak from the 3rd fin up. Over the years I have bought 4 cylinder heads to to try to get one that didn't leak. I also tried welding, resin impregnation and just about anything to stop it, but nothing seemed to work. Only on my 4th head did I find one without the crack, and now I just get a bit of mist around the front studs and the tappet cover studs after a lot of miles.
The amount of oil that comes out of the 3rd fin crack is out of all proportion to the size of the crack- it really gushes out as the revs get up, leaving the bike plastered after a 50 mile ride, which makes me think that crankcase positive pressure is blowing it out.
So I intend to fit a PCV, probably the Yamaha XS650 to stop my misting aroud the the stud holes.
I wish I had tried a PCV before I spent a lot of time and money on cylinder heads as I feel pretty sure that would have stopped the 3rd fin up leak by geting a negative pressure inside tha engine.
On various forums most people have obtained good results with the Yamy XS650 one, but has anybody got an opinion on the one Norville sell? ( although it pains me to buy anything from Norville)
I use the Norvil one on my…
I use the Norvil one on my B44 but I did not buy it from them as its just a plumbers non return valve and cheaper from a plumbers merchant
You will need 2 pipe connectors plus this (just an example)
another example
I have the Yamaha one fitt…
I have the Yamaha one fitted to the timing chest on my 1970 750 fastback. I have it routed into small catch bottle resting between the engine plates below the carbs. it does collect some oil, more the faster you go. but the breather from the oil tank now passes nothing and the condensation from the engine does not now go back into the oil tank. I think the timing cover stores oil when the bike is being driven hard, leading to the oil travelling through the Yamaha reed valve. Jim Comstock in the States drills a 1/4" hole from the timing chest back to the crankcases just below and to the left of the oil pump to drain this oil back into the system.
Previously david_evans wro…
I have two PCV valves fitted to my Commando F/bed both as close as possible to the crank case. These do help the leaks and breathing. I have all my bikes fitted with these and have used them for years, a good mod guys.
Previously john_holmes wro…
another example
I am about to fit a one wa…
I am about to fit a one way valve to try to stop a cylinder head oil leak, in which breather pipe is it best to fit it to ? The engine to the oil tank or the breather pipe from the oil tank to the atmosphere ? Please can you advise.Thank you Alf
Previously john_cowie1 wro…
Cheers - John
Hello JohnI eventually cured the persistent oil weep from the front of the cylinder head on my mk3 by :- sealing the two front 5/16 studs in the barrel with loctite 638, waisting the five head bolts to make them stretch bolts, recutting the head bolt counterbores and making close fitting head bolt washers, this stops the head bolts loosening off with thermal cycling. Using disc spring washers under the 5/16th nuts (this also is to allow the head to cope with thermal cycling). Using copper coat on a new head gasket.Using a xs650 non return valve in the engine breather line.And making/adapting the tooling to torque the head down without having to remove any other parts.Indeed I can retorque all the head fasteners accurately and quickly without dismantling anything even the underneath sleeve nuts.This make retorquing a doddle, so easy its daft not doing so.RegardsPeter
If it's the dreaded 3rd fin down syndrome then according to Mick Hemmings (who explained it to me), it's going to be porosity and/or a hairline crack. This is the point where the head wall is at its thinnest and it is the Achilles' heel of a number of 850 heads from the Mk.ll/Mk.lla era.
I don't think there is anyone around now who is willing to try and weld things up from the inside and in my case that failed anyway. The only route left for me was to attempt a resin impregnation. Alan Goldwater outlined a do-it-yourself procedure in an issue of the INOA's Norton News, utilising one of the Henkel Loctite products. I used a commercial vacuum impregnation company.
Many aluminium castings are vacuum resin impregnated before use as a belt and braces procedure in case they are porous. In the case of many 850 heads, it's not if they are porous, more a question of how porous they are. Having it done was not too costly and it's cheaper if you completely clean the head yourself in advance. That does mean getting it very clean and free from oil; start with a solvent and finish with a prolonged boil in detergent (while somebody is out of the house).
Regrettably, I can't yet report on whether it did or did not work but I am hoping it will as they ran it through the impregnation process no less than four times to make sure. If you search for a suitable company to do this for you, it's maybe worth a try. The one I used is in the Services directory on this site - type impregnation into the key word search box and it will come up.
As a postscript:-John found the source more easily because he has a fairing on his machine. The aerodynamics of the Commando (if it has any!) are such that although the oil emits from the 3rd fin area, it lands on both you and the bike and seems to be coming from elsewhere. It took me a complete engine clean and a good sprinkling of talcum powder before I found it on my bike. It did make it smell rather better than usual though .....
