Crank balance again
Have had a good look through the Forum and read a number of books on the subject. I have my engine in many bits at the moment (52 ES2) so is the ideal opportunity to do something about it if need be. It seems that the push rod engines are balanced to roughly 50% the camshaft engines to 70%. My intention is to run my ES2 in the 50/60 mph speed range. So my question is, are the camshaft engines smoother than the push rod engines at the aforementioned speeds or does the benefit only really become noticeable at higher engine revolutions. I found, before stripping the engine, that vibration was quite harsh at 50 and above. Engine is in generally good condition apart from a slack big end. John
Hi John
My 1934 Inter is ballanced to 70% and is very smooth right up to about 75 (I havent gone any faster yet so don't know after that). So when I built my ES2 I decided to do it to the same factor, I think I actually ended up with more like 68-69%, but this is also very smooth up to about 65mph.
I think 50% would be too low, but can't really comment as I got lucky first time so haven't ridden mine at any other balance factor.
Good luck
Andy
Thanks for comments Andy. Cranks away at moment having new B/E fitted so will give it a go on its return. John
