I have acquired a Boyer power box and am considering fitting it to my Mk 3.
Any suggestions (polite only) as to where it fits nicely ?? I have standard air box and large battery
Boyer-Power-Box.doc
Ok I don't have a Mk3 but…
Hans - not too sure how th…
Hans - not too sure how the Boyer mounts, but I fitted my Wassel device in between the frame rails, and ran the wires up under the tank etc. Involved quite a bit of re-wiring but at least it'll run cool now.
Best Wishes
Jack
Reg_rec-mtg.doc
I got mine bolted to the u…
I got mine bolted to the underside of the battery tray. A tight fit and mine is a Mk.lla rather than a Mk.lll so it might not work on yours. All very good until it goes wrong and you have to dismantle half the machine to replace it.
Ok I don't have a Mk3 but I mounted my Paul Goff device where the rectifier used to be (on a length of rubber mounted aluminum strap). Of course as I write this you may have yr starter solenoid there! It was convenient to put it there as the rectifier, Zener wires and batt wires were easily accessible. Can't think of anywhere else it could neatly fit other than behind the frame plate. It does need some cooling though.
