Can anyone help with information and specs on these camshafts?found in a 750 commando project I've taken over trying to decide whether to leave it in or replace so far only been able to find information on 4S not 4SS
I suspect there is no info…
I suspect there is no info on the 4SS as you have a 4S.
Here is the trace so you can confirm.
http://atlanticgreen.com/images/cam440.gif
If it does not match then you need to check it against the other cams.
http://atlanticgreen.com/camsurvey.htm
