1933 Model 20
Does this year have a 6-volt horn or the bar mounted rubber type?
Can any one reccomend the spark plug for this bike , at present it is still 18mm and fitted with a short reach , (which I know is wrong it should be long ) Is it reccomended that I make a 18mm-to 14mm reduction bush and fit a 14mm plug, if so what plug ?. Cheers Dennis
Hi Dennis
Ithink you could have either type of horn i think the electric horn was an optional extra
I would recomend making an adaptor to fit a 14 mm plug and use a champion n 5 plug or the equivelent
regards Roger
Hi Roger, Thanks for your comments ,I will fit a bulb horn as there is no sign of electric ever been fitted. I will also make the plug adaptor and fitthe n5 plug .Thanks again for your imput,...Cheers Dennis
