Hello. My resto cum recommissioning of the 650ss is progressing. Next on the radar will be the cycle parts. You have been warned!
The subject of my enquiry this time is the front brake cable as it passes the front mudguard.
All my reference photos show that the cable seems to be fixed to the mudguard with a clip or similar, but I cannot identify the correct part. Also my current mudguard doesn't have any holes for a fitting or clip. Could anyone with a 650ss share a photo or part number to assist?
In general terms I am looking for the correct handlebar control cable placements for the 650ss. My current set up doesn't look right but hasn't been a priority up to now
Very many thanks
Kit
You need Bacon's 'Norton…
Its just a shaped and bent…
Its just a shaped and bent strip of metal which could be spot welded or riveted in position. Its likely that the guard is a pattern or incorrect one. Brake cable type will depend on front brake type , single and TLS are different.
Thanks everyone. Happy days…
Thanks everyone. Happy days. I'll try to improvise something with a P clip and a pop rivet. What could possibly go wrong?
Thanks - good point. I don't…
Thanks - good point. I don't think that other than keeping the cable straight and stopping it from flapping in the breeze it does anything safety critical.
If originality is unimportant….
Attached is one I did for Doris a couple of thousand miles ago.
That looks like a winner and…
That looks like a winner and something I could do without too much fuss.
Thanks Alan.
Nice job Alan…
The short roadholder Manx had a similar wire guide to keep the cable from flapping around (somewhat longer loop). What is important is that you don't restrict the movement of the cable when the forks are depressed under braking. The brake feel stiffens if it's too well constrained.
Brake cable
The Nomads used a very neat front brake cable guide that was attached to the stud on the front fork slider. It had a small gap that the cable went through, to keep it in place.
You need Bacon's 'Norton Twins Restoration'. Lots of pictures.
The clip is spot welded to the mudguard. If you don't have one, you will have to improvise.
