WD16H/Model 18 chaincase problem
I have a mod18housed in a wd16hframe and everything was going fine until I tried to fit the outer primary chain case, as the hole for the footrest support pedestal is to high in the cover to allow fitting. I would like to know from any one out there if they know of any differences in 1940s chain cases as I could have miss matched inner/outer covers. I have enclosed a photo showing assembly without the pedestal in place
Attachments 20150404_134355-jpg
We can't see what the problem is from your photo. Is the primary case off a WD16H and the one that was on the bike before you put in the Model 18 engine? Maybe a picture of the innner casing fit would help.
There are quite a number of different 1930s Norton chaincases and it's not always apparent what the changes were.
I'm beginning to wonder if the WD cases were unique. The higher ground clearance of the WD bikes was achieved by shortening front and saddle down-tubes. Would this have led to altered bracketry in order to line up with the rear chainguard ?
The WD bikes did not have footrest tubes welded to the engine plates...could they have taken the opportunity to place them at a different height from standard ?
A photo of your case from the top would be useful.
Hello Dave
Many thanks for the reply, I bought the bike already fitted with the ohv engine and from talking to the previousowner it was assembled in the late 1960s for racing. The cycle parts where a complete mash but the inner chain case fits perfectly with the pedestal( see photo ) could there be a difference between outer covers on wdmachines comperedto the later 1940s mod18 as I think this is where the problem may be
Attachments tyntesfeild-303-jpg
Yes, that looks like it fits correctly. Obviously the foot rest hole in the inner and outer cover should line up, so it has to be the wrong outer cover, unless the outer edge or rubber gasket is misshapen making the holes misalign. Try it on the inner cover without the gasket to see if the holes line up. Sometimes they do need a bit of persuasion.
The correct WD outer has a 'cut-out' or indent around the area of the points cover (just enough to get the lid off). If your outer has a reduced area going all the way to the rear, then based on my observations, I would say it was a post-war cover.
Hello Dave/Richard
Thanks for the replies, I have fitted every thing together without the rubber seal (see photo) and it has just managed to fit but the pedestal is still tight against the bottom of the outer hole. I alsoremoved inner and outer covers from the machine and bench assembled with rubber seal in place, this shows a positive offset of approx3/16" between the holes. The seal is 5/16"x1" section, is this correct?
ps the photo shows the cutout for the points cover so I amthinking that the outer cover is correct
Attachments new2-006-jpg
All the casings I've seen have a cutout for the points cover. I've looked at my 49 ES2, my 42 16H and another outer case that I think must be off a swing arm ES2 and they all look the same. The differences only show up when you mix them. I've never had my ES2 and the 16H cases off at the same time to see if they are interchangable.
I'm sure the holes in your cases should line up but as long as you can get it to fit I wouldn't worry too much. It looks fine in the picture. Getting it to seal will be another battle. I'm running my tin primary's almost dry these days. A splash of oil every so often to keep it lubricated and I don't expect it to stay in there. I've never had a problem doing this.
I'm interested to see you have a 46 Model 18 engine in your 16H frame, that's exactly the same engine I'm putting in a WD16H framesmileyI would like to see a full picture of your bike please.
Dave/Richard
I think your right, I will try running as you suggest once the bike is on the road and come back to it then if it causes problems. The bike is still in the pre-painting stage as I am still making sure everything fits correctly, the tank is away for mods at the momentso I hope this photo is of some use
I have tried loading more than one photo of the bike but the site will only let me send one at a time, and then it has to be cropped down. If you wish to ring me my no is 01472 319094
Many thanks for the help
Attachments the-job-so-far-003-jpg
That's lovely thanks Paul and very similar to what I'm building. I'm glad to see it all fits in the frame ok. I'm in the middle of building the engine for it, then I have to finish another engine rebuild to clear a bike off the bench before I can get the rolling chassis together. I think I've got most of the parts I need now. I'm interested to see how your progressessmiley
I've not studied the post-war singles but have noticed that some (plungers ?) seem to run straight back from the points cut-away whereas the pre-war types seem to drop back in again.
Paul's cover looks correct for WD16H engine plates.
This is a post-war plunger in Andy Tiernan's archive (hard to find a decent plan-view photo of the cover though)
This is my case viewed from above showing the clearance for the points cover as an indent rather than a change of line going all the way to the rear.
[IMG]http://i248.photobucket.com/albums/gg164/commando16h/NOC/Battery_zpsso1hjbvk.jpg[/IMG]
http://www.andybuysbikes.com/archivehtml/5493nrt.html#
I see what you mean Rik, however my 49 ES2 has an outer case the same as a WD16H as far as I can see? There's always as chance mine has the wrong cover so I've just Googles it and the other ES2's of the same year have the same case that I can see.
[IMG]http://i1080.photobucket.com/albums/j331/Horror/P1010001_zpsvonnsa1p.jpg[/IMG]
I've just checked some old pictures of my 52 ES2 and that has the same cover too.
[IMG]http://i1080.photobucket.com/albums/j331/Horror/DSCF0022a_zpsx9n1mw08.jpg[/IMG]
The cover I've got that is straight after the cut away is for a swing arm single I think, but I'm not certain, so that would suggest it came in in '53..?
[IMG]http://i1080.photobucket.com/albums/j331/Horror/Norton%20Primary%20outer%202_zpsehcukcpz.jpg[/IMG]
Just my observations, I could be wrong.
Hi chaps
Just had a look at the recent photo's which the covers fitted well on to the seal area, does any one know whether these pic's are with the seal fitted or not. Also if the wdmachine has the seal in, what section rubber was used as mine holds the cover back off, see photo.
ps does anybody know the correct length for the wdclutch pushrod. And is it possible to buy a 1"diadecompression lever from anywhere as everything I've seen seems to be 7/8"
Attachments top-view-001-jpg
Paul, the WD bike is mine. It certainly has a rubber in...supplied by Russell Motors, as I recall. I have an idea that alternator cases use a thicker rubber ?
Paul... my cover is also too far out. I managed to get the nut on but only just. The band was new from Russels...the old one was stuck and took ages to cut away with a steak knife bent at right angles at the tip.Maybe that was too tight years ago.Seems like today's bands are too thick.
Many thanks for the extra input chaps,I think I may start searchingfor new inner & outer coversand see if I can get a Matched pair as it seems to be the only way to get things to fit correctly.
