Basic stuff - new Big 4 owner
Hello All,
I have just bought a very originalBig 4. The bike has been used lightly but occasionallyand has fresh oil.
This is something of a landmark; although I have had quite a few bikes they have all been considerably younger with more modern engineering and an electric boot. The PO has been very helpful in describing the starting procedure but there are still a few gaps in my knowledge with regard to starting the bike without incurring bodily injury and I would value your comments on my current understanding. If this info is elsewhere please let me know, I have searched the site and have Members access but have not found any such basic information for those unfamiliar with old Brits.
So here is what I know/don't know:
When the bike arrives it will have the oil in the sump. Can I use the kick start to pump this in to the oil tank ready to start or do I need to drain the oil?
I then operate the choke to open and retard the ignition. The bike can then be kicked over with the decompressor open.
Long swinging kicks are to be preferred. Should the bike be on the mainstand at this point or is it easier astride? Should I position my foot or legin anyway to mitigate the effects of possiblekick back?
As soon as started close the decompressor and then advance the ignition and ease back the choke.
I am obtaining a workshop manual from the PO which I also hope to be instructive - are there other sources of maintenance information I should locate?
Many thanks
Dave
I'd suggest you download the WD Norton manual from wdnorton-NL web site. Lots of useful stuff.Another thread on wet sumping cold run and run forever! FWIW I usually just start my 16H and let nature take its course. It depends a bit on whether you can kick it over quickly enough to start it.Everyone says 'long swinging kick' but all I've even been able to do is kick the lever through the half circle defined by its length!Wear big boots until you are used to it. If it turns out to be hard to start there might come a moment when you accidentally leave it too far advanced and it will kick back. It ought not to be too vicious unless it is very far advanced.As for where you stand - it's up to you. Usually I have the bike on the stand when it's cold. I stand on the right and kick with my left leg. But I get odd looks and nobody else does this.I found that mine starts better if I tickle the carb but then kick the engine over a couple of times with decompressor part lifted and a couple of fingers over the carb inlet just to choke it a bit and make sure fuel gets inside. That's not in the books but some other riders do it apparently without thinking.Where do you live? Go along to your local NOC branch! It will have people who will be delighted to help someone playing with a new toy!It'll be interesting to find out what other owners do differently. This site could perhaps do with some basic instructions for new owners who have been brought up with modern machines and don't have someone nearby to assist.
I wouldn't think that the bike will start with the decompressor actuated.
Normally you use the decompressor to relieve the compression while you bring the piston to the top on the firing stroke. Then you close the decompressor and give the starting lever a good kick.
You will master the knack shortly.
...Hi Mike ... I wasn't trying to suggest it will start with decompressor lifted! Just that a few prods slightly choked just helps the fuel to get where it is needed. And if compresson is reasonable it can't easily be done without lifting the valve a bit.
If it's been standing for some time I would suggest that you drain the sump and return the oil to the tank before you try starting it as, if you succeed in starting it with a lot of oil in the sump, much of it will blow out of the breather and the bike will mark its territory in no uncertain terms! Also, a wet sump situation will make it harder for you to kick the thing over at a decent speed.
I'm assuming, from what you've posted, a general unfamiliarity with old Brit iron, in which case, time-honoured starting procedure for most/all types is:-
Turn on petrol tap; tickle carburetter until either petrol seeps past the tickler or your finger feels wet; gently but firmly push kickstarter down until compression stops it from going any further; operate decompressor while moving kickstarter down slightly to ease past tdc; release decompressor and, with advance/retard on full retard and choke lever closed (parallel with handlebars) perform a determined one-legged jump on kickstart, either astride bike or alongside it while it's on centre stand. It may start.
I don't recommend starting a Big 4 / 16H on the stand, this can twist it and damage the threads in the pivot. Stand astride.
Thanks Gents for sharing your experience, I now have a clearer picture of the correct starting sequence.
Good website the WD NL one, thanks. Got the Nortondownloadand pretty comprehensive it is too; at least by modern standards.
Nearest NOC branch would be Tay but eventhey are many miles South, nothing very local although my local classic bike club will have the knoweldge somewhere I am sure, just need to tap into the right person.
Once I have themachineI will post a photograph.
Best regards
Dave
One other thing to note is whether you have tight or slack wire advance. If the Mag has been changed either could be true. Take the points cover off and note direction of points rotation. If the camplate rotates in the same direction when the advce lever/cable is pulled,the ignition will be fully advanced with the cable slack. If it moves in the opposite direction to the points when the lever/cable is pulled then you havetight wire advance. Important for the survival of all those teeny bones in your foot! Mags have an optimum point of maximum flux, either side of which the spark intensity is lower. Too far retarded may also cause you problems. I usually retard no more that halfway and give a 'confident' swing. Mine has the 633 long stroke engine which is more challenging still!
Have fun.
I'm just another new (3 days) 16H owner. Howards starting method is the same it's previous owner told me. Most times it takes me 3 kicks to start it cold, sometimes less. But I have not understood how to start it when it's warm. What is the normal warm start procedure? I'm aware of that the old ladies can be different and have to be treated individually. I'd really appreciate some hints before starting to investigate possible magneto or carburettor issues.
What do you mean by 'warm' ? If you stop the engine and immediately try to start (without touching choke or 'tickling') and have difficulty using the same technique then you probably have a problem...If you leave it for a half hour or so then ambient temperature and fuel type will have an effect.
Make sure though that you don't accidentally open the throttle wide as you kick. Side-valves don't seem to like a large throttle opening when starting. If using choke, this effect is disguised.
'I'm aware that the old ladies can be different and have to be treated individually.'
This, really, sums up the reality of the situation. Whereas modern machinery should and does start instantly, hot cold or warm, machines from the 'old clunker' end of things often exhibit a perversity that can either be regarded as 'character' or 'a total pain in the backside', depending on your frame of mind, need (or otherwise) to get somewhere quickly or whether or not there are interested onlookers.
The only way is to persevere with different techniques until you suss out the particular foibles of your own machine. If it's up to full running temperature, it should start with nothing more than a determined lunge on the kickstart (with ignition retarded slightly for safe preservation of the delicate bones in your foot!)
If, however, it's just 'warm' it may need partial closure of the air lever or even a couple of prods of the tickler button (not the full monty flooding of a cold start though).
An interesting technique that I was shown by top Velo restorer Martin Arscott (albeit on a Venom - one of the most cussed recalcitrant starters ever produced by the Brit bike industry) is to 'get it firing in the pipe'. His approach is to go through the usual preparations for starting, either from cold, warm or hot, but then hold on to the valve lifter while vigorously kicking it over until it literally starts firing in the exhaust pipe, at which stage he releases the lifter and continues to kick. It then starts (or it did for him - must admit, I never had much luck with the technique but then, it was a bloomin' Velo after all). Anyway, good luck with it.
I have to put the possibility of kick-back out of my mind entirely or I can't kick properly. It is a psychological thing. You may find that you don't suffer from this at all though.
Hello David, i am in the Tay Valley Branch and i run a Big4, if i can be of any help let me know, Cheers..
Hello Richard, you are right about starting it immediatly after a short stop. Now I have to figure out how to solve my problem starting it after a ten minute pause. Guess some trial and error will sort it out.
Hello Guys,
Well I have started it several times, it takes a long time from coldso I am evolving the knack for this machine....smiley
Thanks Sandy for the offer, much appreciated yes. Once I get the starting sorted I'll take a trip down the road to compare notes.
In the meantime here is the machine - we all love a photo!
Dave
046-jpg
Gents,
Please humour me, the positions of the ignition and choke levers on the attached photo are:
Ignition (left) fully advancedas it should be once the engine was running normally
Choke (right)is also fully closed, as it would bewhen you want to start the machine ( as per Howard's post above, choke parallel to the bars for starting).
Correct?
Dave
039-jpg
It all looks plausible!Have you checked that the air slide is down when the lever is forward? It's not all that easy to see down the throat of the carb but it's pretty obvious when you open the throttle if the slide is down.On ignition - some people paint dots on the lever to make sure they align the lever in the position the engine seems to most prefer. For what it's worth I usually advance my 16H a bit more (lever a bit further back) but no doubt others will say different. It shouldn't be a violent engine.Do you have correct plug and magneto points gaps? New plugs today seem to claim to be properly gapped out of the box - at about 28 thou for most modern ignition systems (or whatever that is in metric) but the magneto prefers a smaller gap of maybe .020".When hot it ought to start easily enough although the carb might dry out a bit after a minute or two and it might need a little tickle of air lever again to re-start. But as others said above - they do differ a bit.And remember -the carb does not have an accelerator pump to enrich the mixture when it is opened quickly, so as a soon at is starts it's safer to open the throttle steadily and do not 'blip the throttle' to catch the engine start. That will make it instantly too lean at it might well stop straight away. Enjoy it!
Thanks David. I am getting good sparks, had the plug out, cleaned and gapped as per ,manual and points ditto. There are 3 pen marks on the ignition but no idea what they mean!
Carb leaking, sticky float so need to look into that, may not be helping
Dave
