in my last post I was awaiting collection of my new project - my first Norton - a 650ss in an Atlas frame. I was pretty certain the engine is one of the first 650ss from Sept 1962 as the serial number and stamping says so. The frame is more of a puzzle.
I’ve only just been able to uncover the serial number for the frame and this says 88-116258 (picture attached) and for the life of me I can’t find a prefix with an 88 anywhere. From the frame number alone it looks like a late 1966 Atlas.
Any ideas? If it is an Atlas then shouldn’t the frame should be a 20?
From my reading it seems that there was little or no difference between the frame and cycle parts of both models so hopefully there won’t be too many issues with my rebuild. I’d be grateful for a heads up if this isn’t the case.
Kit
Oooopzzz Time
The frame number points towards a 1966 Model 88SS.
I might be wrong but generally the frame is stamped with the Model indentifier.....which for a 500c Norton would be 122 and not 88.
On the frame plate......14 would be used for a 600, 18 for a 650 and 20 for a 750 engine.
The 500cc range used 12, then 122 and finally 88SS on the left engine cases.
Your frame is a post-1963 version of the Slimline which was used by the 88SS, 650SS and Atlas engines. These frames have the welded-in top gearbox cross-bar.
The engine seems to have a…
The engine seems to have a barrel from a 99 Model. That's fine so long as if the rest is 650cc it will have had the slots added to the barrel for the heavier con-rods. I have never seen 88 stamped on the frame plate. You could change an 8 to a ! as 18= 650cc. Good luck, Howard
Thats a good Puzzle. Early…
Thats a good Puzzle. Early front end , 99 barrel, (well spotted Howard) later frame , later ignition switch position. could be a 650 or 99 capacity with those cases . It most likely to be 650 cc but could have issues with 650 pushrods and 99 barrel , or 99 pushrods with 650 valve springs !. Could even be a very low compression engine with an 88 crank and 99 pistons ! . Its all been done before to use up parts . If it runs and rides ok then why not ?. I like the workshop, mostly wood (kind to old bikes) with good light .
Thanks!
The bike last ran in the early 80’s and it’s been creatively fiddled with in fits and starts ever since. The previous owner has memory issues (and it was a while ago to be fair) so I really can’t trust anything much about it. I do know the crank cases are 650ss but the 99 barrel is news to me.
Bike turns over ok but I think it’s probably got to be a proper rebuild on the engine because there are bound to be other issues. So much for his comment about just adding fluids and it will run!
I have similar issues with…
I have similar issues with my 63 , later wrong headlamp ,clocks etc . Also not run yet , how far to go with checking ? . Your rear guard looks odd , ?? .
My year 1963 88SS has plain…
My year 1963 88SS has plain number 10xxxx on the frame. No model number. The engine is numbered 88SS/10××××/P. No sign of a 12 or 122 on engine or frame.
Looking at your frame and…
Looking at your frame and the top of the area cleaned off , it would appear there are other numbers you have yet to reveal .
Steering Damper - Does this help?
There is an fugly steering damper on the bike - photos attached - but I’ve never seen a steering damper in any of my Norton books. Is this a clue or a red herring?
Hello again Dave, The…
Hello again Dave, The engine number that you quote is a Plumstead one. The slash P as a suffix signifies this. The crankcases on these later bikes did not show the 122 Model number but it was still evident on the frame plate. Is it possible that you have yet to remove enough paint to reveal it ? Good luck, howard
The PO masked off a…
The PO masked off a rectangle over the frame number when it was powder coated. Then varnished the numbers so they remained visible. Don't know why, except that they might have been impossible to read under the coating if the frame was grit blasted. It's just possible there might be something under the paint above the '1', but I don't think so. It doesn't concern me.. it matches V5C.
Kit, the steering damper you…
Kit, the steering damper you show on your images is a Norton Accessory that was available as an extra from 1962 for the SS Solo Models. The kit had Part number SD/4 and with all the fittings it cost purchasers a measely £1 6s 8d. regards, howard
Damper not really needed for…
Damper not really needed for solo riding but very usefull if leaning the bike against a lamp post ,tree ,wall or inside a van , locks the steering. Also cannot be ridden .anti theft !. Instant crash.
Odd Numbers
The numbers stamped on the frame are not Bracebridge or Plumstead numerals. Style is more like those for a Japanese engine.
Any chance of a clearer photo of the engine numbers???
More Engine Numbers
Thanks for the information everyone. Really helpful. It’s proper detective work. As requested more engine serial number details. I’ll get the tank off and look at the head in more detail next.
And the serial numbers
From the head and cylinder barrel too for completeness. I think I have a bit of a FrankenNorton thing going on here!
More ID Numbers
The engine number is for a 650SS built just before Sep 1962 .
The barrel number 22709 was used for both 99 and 650 barrels but as Howard says the fins suggest that it belonged to a 99 in a previous life. The problem with using an early 99 barrel on a 650 engine would be the size of the pushrod tunnels. These were generally not large enough to cope with the fatter SS pushrods operating inside without rubbing against each other or the barrel / heads lips. The later 22710 99 / 650 barrel had larger P/R tunnels.
The cylinder head is the correct 650SS 22707 item.
The three barrels shown are left to right a 650 then late 99 and finally 88 dynamo engine. Your barrel appears to match the centre version. Note how the top fin of the centre barrel has a straight front edge and hence more surface area where the head exhaust ports would be..
Thanks Phillip
That’s a brilliant explanation of something that I was puzzled about. Seems like the best long term solution is to acquire the correct 65O SS barrel and a matching set of pistons. If what you say is correct a new set of pushrods will probably be needed as well. This seems to have been a parts bins special lash up and sadly I have to assume the worst from now on really.
I wonder what story the frame will tell.
Why worry at this point?
A question that you need to ask yourselfbefore you get too deep is what exactly are you wanting.
If you aspire to an 'as it came from the factory' machine, then go ahead and seek out the barrels/pistons and various other parts you need. Might become expensive mind you. Then you will find some people saying it isn't 'matching numbers' so it isn't a real one.
If you are simply after a reliable 'old bike' then why worry too much. There is nothing wrong with a 'mongrel ' as long as it has been assembled well- my bikes engine, gearbox and frame certainly didn't leave the factory (factories?) at the same time but it is, to me, none the worse for it. It gets ridden a lot.
Be aware that 650 barrels came in spigots and non spigoted types, and you will need the correct type to go with your head. If the crank and rods are indeed 650, then the barrels you have must have already been modified to suit and should work just fine.
Add in that the pushrod issue is only really relevant on how you intend to use it. If you have the 'SS' valve springs (only needed to stop valve float at very high rpm ie. over 6500-7000rpm) and intend to use the full rev range, then the stiffer pushrods are a very good thing. If you intend to use it like most owners nowadays where a max of 5000 through the gears and cruising at a max of 4-4500rpm seems the norm, the earlier springs and slim pushrods will work perfectly well for you.
Best thing is that this club is made up of a lot of really helpful members that will offer advice and help to you.
Unless I missed it, you haven't said whereabouts you live, but hopefully there is a local section not too far away. You could find that meeting up with fellow 'Noccers' quite invaluable.
Keep asking.
Regards,George
Thanks George
I’m just working out what I have first but to be honest once I knew it was a bit of a mongrel then it’s got to be all about ride ability and reliability. I’m unlikely to be thrashing it well over road legal speeds so as you say - it might be fine. Time will tell but I already know loads more about the bike than I did last Saturday. The project continues but a strip down seems essential.
Oh I’m based in South Bucks at present so that makes me a Thames Valley member.
Finding "correct" good…
Finding "correct" good quality parts is now a difficult process ,and as George says pretty pointless if the bike works well . I do think that its prudent to look carefully at the whole bike as this should give you a good idea of the level of mechanical competance of the previous owners and go from there.
Yes I have asked the records team for their thoughts too but doesn’t hurt to ask!
