Hello. First time poster and very new member here. Be gentle.
I have just inherited a 650ss Dominator which has been standing in a conservatory for the past 10 or so years. The bike is in good cosmetic order and I like the patina. Whist confident enough to service and maintain the bike I honestly lack a few basics, such as the space, skill and tools to get the bike recommissioned.
OK. The bike was free to me and so I’m happy to invest in getting her running and reliable-ish. I would like to have her running for Summer 2024
I live in the Slough area - someone has to. Does anyone have a recommendation for where to do the work or perhaps more importantly who to avoid? I’d be grateful to hear your thoughts.
Thanks for your time.
Kit Lewis
Was the bike woking 10 years…
Was the bike woking 10 years ago?
You may need to do little more than fluids / tyres / chains to get it back on the road, and then learn and fix as you go.
Do you have no space at all? Kitchen / spare bedroom? - Only kidding.
If you got yourself along to the next Thames Valley branch meet (https://thamesvalley.branches.nortonownersclub.org/)
I am fairly sure we could come up with some help. If you do, then bring plenty of pictures.
Thanks Tony.I’m sure the…
Thanks Tony.
I’m sure the bike was working before it was laid up. The owner greased all the metalwork and disconnected the battery. He also told me he had oiled the bores but that will be long gone. It does turn over but the carb is gummed up. The gear box seems to move but obviously hasn’t been run through yet. I’m worried about the fuel tank and think it may also need a good clean. There is no obvious rust in the tank but worry it might be leaky. Not had a chance to look at brakes yet.
Now I’m a Norton owner (even if by default) I will be keen to get to know what I’ve taken on and will be a sponge for all things Norton. I’ll certainly be along to the Thames Valley gatherings with photos and hope to enjoy the Norton experience!
Genuinely have no space - just a 6x4 shed full of junk! No it’s not going in the kitchen she said.
As Robert says...Better you…
As Robert says...Better you get to know it. Recommissioning will be good experience. And then you'll find out if you do need professional help. If it worked well when it was stored, you can be reasonably confident that nothing has broken. Engine internals should be fine if they were oiled before it was laid up.
It will have wet sumped, carburettors will need cleaning (tiny air passages), clutch will probably be stuck, all fluids will need to be changed. But none of those jobs is difficult. They just take time. Fuel tank is unlikely to be a problem, unless you are very unlucky.
Join your local NOC branch. You'll find local advice.
Remove the Oil Tank
I'd remove the Oil tank and thoroughly clean it with kerosene, or if you live in England, paraffin.
Drain the sump and gear box.
Remove the fork drain plugs and bounce the bike up and down till all the oil is gone.
Check if there is oil in the primary.
Pull the clutch in and kick it over until the clutch frees.
Lube the cables and replace as necessary.
Pull the float bowls off the carbs and if any sign of white gunk, remove and clean the whole carbs properly.
Buy small plastic fuel filters and fit in the fuel lines.
Lube and adjust the rear chain.
Refill all the fluids .
Lube the wick in the magneto. Check for spark.
Reconnect the battery. Check all the lights work.
Pump up the tyres
Take it for a very short test ride then check for any issues, e.g.. brakes, leaks, fuel blockages, gear and clutch operation, primary chain tension , tyre condititon, check the head light brightens when you rev it, check oil is returning to the tank, etc, etc.
Good luck, it sounds like you have a good one.
Don Anson Melbourne Australia
time
We don’t know what your experience level is in dealing with mechanics on vehicles?
How much spare time do you have etc etc? Will this be the first part of a new hobby, and therefore more worthwhile to learn the skills now for future use?
What is your budget, as professional help from a reputable source ( and there are not many of those!!) can very quickly add up?
You did ask for professional…
You did ask for professional help. There are a small number who advertise in the shiny bike magazine small adds.
Is there a detailed Roadholder article about recommissioning?
Most of us probably had no professional training but in the days when most owners were forced to maintain their own machines there was usually a more experienced friend or neighbour to help us when we first started taking things apart. That's not often the case today. But cleanliness and care and preferably more than one instruction manual will take you a very long way.
Thanks!
I’m grateful for your thoughts and encouragement and the checklist above looks like a useful place to start.
OK, I do have some previous experience and have ridden and owned a VH500, a T140 and a B40 back in the day. I rebuilt all of them but not with any real confidence and in the case of the T140 very badly. But I can find my way around a Haynes manual. I have a few tools. So I can do the day to day fettling but I know and understand my limits.
This opportunity is a surprise and the thought of being on two wheels again has rekindled my previously filed away passion for classic bikes. Never thought I’d have the chance or could justify the cost. I’m having to reevaluate the space I have to work in but I’m definitely going to need help and assistance with getting it safely on the road.
As someone hinted at in the replies - no one bounces as well as we used to. I've done my share of that and have no wish to repeat the process! I’m picking up the bike soon and I’ll get some photos and a decent look at what we have and try to provide a condition report.
Kit
Tip. As suggested,…
Tip.
As suggested, drain the fork oil by removing the two drain plugs having beforehand put catch trays underneath. let them drain naturally then tie rags around each fork loosely covering the orifices, then bounce them up and down!!
You now have a shed with oil free walls with the added bonus of an oily pair of rags!
Assuming that the gearbox still has oil in it and isn't white with "mayonnaise" all should be well.
If you don't want to strip the head down completely a reasonable valve leakage test is to pour a teaspoon of white spirit down into the ports to see how much seepage there is.
Also look at the valve stems to assess how much carbonised oil has been deposited on them.
If you know the mileage to begin with this can tell you a lot combined with what you uncover as you go along.
...and I probably don't need…
...and I probably don't need to warn you - but don't take things apart just for the fun of it! There are those who say more bikes have been lost due to unnecessary fettling than from any other cause. (e.g. don't try to change the swing arm 'silentbloc' bushes unless you enjoy pointless pain and anguish.)
Update
Ok. Just had first chance to look over the bike and it’s a bit grimmer than I thought. Might as well be a barn find not a conservatory find.
It’s apparently a 1966 650 ss engine in an Atlas frame. I can’t verify that but have no cause to doubt that info. Is this an issue?
The bike turns over but clutch plates are stuck. Carbs look proper sticky. There is oil and petrol in the respective tanks but She may have been stored for over 40 years. I certainly recall seeing her last back around 1975.
Any idea what the ignition set up is? Hopefully I can get spares. I do have the magneto but would prefer to keep the twin coils.
Any nuggets of wisdom?
Does not look too bad. The…
Does not look too bad. The bike is 64 or later probably. The ignition is a boyer which needs a charged battery . and might not need to be messed with. the clutch will need to be dismantled and washed in petrol and re asembled . Might need internal rubbers changing .Will need a proper service , brakes and tyres checked. Join your local branch.
More photos
Some more photos - I think it’s a 1962 engine using Roy Bacon’s data.
Yes - a Boyer - thanks - but I can’t decipher the model number - any ideas?
I think there are issues…
I think there are issues with the head holding down fixings ,barrel fixings and also a missing case stud and nut. with these 3 obvious and simple errors i would not be confident that its been properly assembled . Get someone competant to look around. looks like it was thrown together to be off loaded. Where are you based ?. Clutch cable is likely too short to allow proper set up for internal clutch lever and pushrod ,very poor clutch cable run, Alternator stator fitted in reverse . think its not connected?.All good clues as to previous owners competance. Still a good project that will make you an expert, (sooner or later!). You want more problems ?, give me more photos !.
Be cautious…
The rear cylinder base nut has a stiff wire under used as a pointer for a timing disc? Alternator wiring is with a domestic 3 core cable with some dubious looking soldering at the coils. It looks like it’s been kept going my an enthusiast, but to be confident of a reliable machine later be suspicious of all non original work. But as already stated doesn’t look to be a difficult rebuild, quite complete, but in need of thorough checks.
Enjoy :-)
I think the alternator is…
I think the alternator is the right way round. The white wire looks like a timing pointer. The second base bolt from the front is wrong.
The alternator..
The alternator doesn't have a right or wrong way. Except that the wires must stay away from the P chain. And the gap rotor/stator must be 8 thou or more. The model of Boyer ignition is NOT critical if it sparks go for it. The alternator looks like the 1962 or early, this is NOT an issue. But it is a bit tired (we all are after 70yrs). Alternator life, working etc leave till the rest is done. The machine is 12V good, but after 10 yrs of doing nothing a new battery will be in order. DO NOT worry about battery charging at this point. Get the engine running and the clutch, then worry about oil and tyres. If the battery is new and/or well charged the bike should be ok for a 50 mile gallop to see what works or not. WHEN the engine runs nicely and the throttle works full range and all the gears are there and the oil goes round every where it is supposed to and nowhere else! Then worry about the battery charging. You said in an 'Atlas frame'. The frame 650SS and Atlas is identical. Alternator good/bad can be sorted as a separate issue in due course.
It’s my cousins bike but I’m…
It’s my cousins bike but I’m not sure when or if it last ran. Even to my relatively inexperienced eye there are some issues. I can’t be too snippy though. Hopefully we can get the old girl back to life after such a long time.
Hi Alan , the official…
Hi Alan , the official Norton line is that the alt leads must face the engine ,probably to avoid the case contact and they do say that it wont work correctly if reversed. ! . I dont see why either .
NONSENSE
The Lucas (and Wipac) permenant magnet alternator is a coil of wire with a PM wizzing past it, it does not know which direction from or going so the idea of 'won't work correctly if reversed' is nonsense!
I don’t have the frame number
I don’t have the number to check the Atlas comments but that’s what the previous owner said so it will do for now. The bonus is that it allows me to have the tank painted red in the future - or not. Bit of a way to go first.
thanks for everyone’s comments and encouragement. Let’s see where this takes me. More in 2024.
Frame ID
Would be 20 for an Atlas, 18 for a 650. It’s on the left gusset plate just above the footrest. Take a look in the online Library for good information on your type of machine. You got some weeks before you need to be road ready so just go through it end to end like any machine and ensure it’s all there within acceptable wear limits and lubricated as appropriate. Make a list of bits to improve, you will have a fine machine in the end.
J
Classics are all about enthusiasts doing it themselves. Whenever I work on a bike that others have built l finish up taking most of it to bits again . If you don’t know your bike intimately how will you fix it on the road? . Todays idea of a service won’t cut it on a machine that’s 70 years old and may have any number of latent issues?. How will you find out that the fork leg is cracked through and the box bearing is about to lock up if you don’t spend the time to look? No one else will . Old bikes can be full of nasty bodges , you could just trust to luck if you bounce well .
