Hello all,
I am having trouble sealing the primary chaincase on my 1946 16H.
I bought a new 'rubber seal gasket 5/8" x 3/8" section' from David Wilkinson, Classic Motorcycle Spares.
The new gasket looked OK and it fitted nicely over the lip on the backplate (exactly the right width) ... but I could not get the chaincase itself to fit over the gasket.
So I trimmed the new gasket down a bit to reduce the thickness and then liberally applied sealant around the joint.
On the face of things this appeared to be successful ...
I waited a week to let the sealant harden but when I tried to refill the chaincase with oil it just p....d out !
Any help would be much appreciated.
Hugh
Hugh - I have the same pro…
Thanks David, In the previ…
Thanks David,
In the previous threadSkip Brolund mentioned a tapered cross section gasket.So I am going to buy another 5/8" x 3/8" rubber seal gasket and cut/file a smooth taper around one edge and reduce the width if necessary. I will also take more care with the cutting this time. Hopefully this will at least reduce the leak rate .... Thanks for the advice on the sealant.
Hugh
RacingNorton.co.uk sell tw…
RacingNorton.co.uk sell two sizes of chaincase sealing rings. They are at the bottem of this page.
Ian
Hugh - I have the same problem. Last week when a thread started on this topic I followed the lead and ordered a new gasket assuming it would solve the problem but I (foolishly) did not take the case off first to check mine. So of course his is identical to mine anyway...I can only get the case on by using a half-thickness nut. There must have been a smaller section on the early singles. But how big? And are they available anywhere? I would guess they have to be something like 3/8" square.Take care with sealant. It took me hours of hard work to remove the one it had on before. I suspect that was too big, and PO had jammed it on so it was stuck fast after 25 years. I had to put a 90 degree bend in the tip of a steak knife and saw it out!
