Hi, I have just acquired my first Norton, (I'm a Velocette / BSA man) and I need some help identifying my bike.
The frame number is 9326 and is a plunger frame with Roadholder forks. According to the logbook the engine number is B.10.M.10096 but I cannot find it stamped on the crankcases. The only stampings I can find are 71x88 which confirms that it is a 350cc machine. It is an OHC engine and I believe that the bike was used for Grass track in the past.
My reading of the internet searches that I have done regarding engine number lead me to believe that the 10 stands for Model 40. The M I believe is a year number, which makes it a 1957 engine. However, other notes show the M as standing for Manx! The engine has an alloy head with a much darker material cambox and cover, running a 10TT9 carburettor.
To you Norton experts this must seem like a simple query, but I am confused by the numbering and the historical side of this bike. It is in need of TLC and I want to make sure that I get it right when ordering bits. It runs beautifully and starts first kick, every time, but cosmetically it is very shabby.
Any information would be gladly received by this newcomer.
Chouk out the link for format
Not an expert
The logbook number suggests a 1947 (letter B). The 10M suggests a model 40M Manx 350. The serial number 10096 is in the 1947 range. So the original engine was a doubleknocker.
What your engine actually is I don't know, but maybe a pre war one. A cammy (SOHC) 350 engine with probably magnesium alloy parts. The TT9 also might be pre war.
It is fairly common that old bikes used for racing got a lot of transformations. An original race bike is a very rare bird. Hopefully you will get better answers from our wiser members.
machine record
The club holds factory records for this period. I suggest that you go to "records" on this website where you will find information about how to obtain a dating record for the frame and engine.
1947 40M.
Hi William,
Your frame and engine look correct for a 1947 350 Manx, and the number 9326 could be a shop frame number for production reference. The frame number should be on the left side of the front petrol tank lug, or possibly the front engine lug. The engine number should procede the 71 x 88, unless the crankcases have been replaced and not stamped up. Both these numbers should be the same if they are from the same machine. The DOHC engine wasn't available to private buyers until the latter half of 1949.
Looking at the other parts on the bike, it could have been built up from spares. The gearbox is the early post-war road spec type and the oil tank is also road spec. The carb and the mag are both as used on the standard Inter and would have had a dynamo fitted for road use.
As Tim says, your best bet would be to get a factory record, but your will need to find the frame and engine number first.
It's an interesting bike
with some variations from what one might expect as a 'catalogue' machine. The coding B10M is exactly what I would expect for a 1947 350 Manx.
I would say that the engine is mostly Manx, but the cylinder barrel looks like an International one - it appears to lack the 'square' top fin and rapidly tapering to round of a low-case long-stroke Manx. The upper bevel cover plate is for cam-centre oil feed, but is alloy, I would expect it to be magnesium. Some Inters got alloy cam-box and magnesium bevel plate. The cam-box is magnesium, and not machined for a decompressor.
Having said that, this could be one of the very first Manxes made. (Pedant note - the 1939 customer racers were 'International Nortons to Manx specification', and were not 'Manx Nortons'.) The factory may have been short of parts, and eager to get machines out the door to customers at the IoM, and used what they had.
I would say tidy it up and get it running. If you take it to an event or two in its grass track form, it may attract attention from old-timers who may remember how it was done 'back then'. You may find out about first-batch Manxes and grass tracking mods of the day.
Could you post some more pictures of your bike?
It would be really interesting, and help with identifying what you have
The plot thickens
Thanks for your helpful advice so far. I began by trying to get a factory record reference as advised. The record request says that I have to supply pictures of engine and frame numbers. So I set about tracking them down. The frame number for a 1947 machine should be on the left hand side of the front downtube, but it does say that very early frames had it under the seat. No joy at the front, so had a look under the seat and found a stamping. But on first inspection the number did not seem to match the log book entry. So I have scraped off the paint and there was a 5 figure number instead of the 4 figure shown in the log book. And it was stamped on upside down! The number under the seat is 13166. This still fits a 1947 frame number but that is not an "early" machine and why would it be stamped upside down?
Still, off I went in search of the Engine number. This appears to have been ground off! There are some stampings at the front of the drive side crankcase but they read XM32. (see pictures below) So all I have to go on is the log book entry. Now, That should match the frame number but I do know from the previous owner that the engine was changed at some point and prior to him acquiring the bike in 1982. The number on the log book (and the continuation log book) both show B.10.M.10096
The other odd thing is that I also have the "Continuation" log book from 1960 and it says that the bike was first registered in 1954! That date doesn't match anything that I have found so far. So, could it be possible that this frame and the original engine were sold for racing and not road use and then subsequently registered later? None of this makes any sense to me, so any help solving this riddle would be good. Paul Standeven has asked for more pictures, so I have added 2 more in a separate post (due to file size)
Is on the top casting on the seat post. Often upside down. I have it on both my plunger frames, so I believe it to be a part number for that casting.
That is a full on Manx spec frame, with the “V” cut lugs and window tank and engine lugs.
As Paul said this is a very neatly turned out machine. Not a million miles away from ready to ride. . Many interesting features that I’m sure the specialists will pick up on.
You have the necessary documents to register. It predates requirements for testing so if you feel confident to go over the basics and necessaries I would get a few miles on it and then work out what to do about authenticating later.
Very nice find :-))
J
It is already registered and…
It is already registered and has a reg number. When I bought it I even managed to transfer ownership on line via the DVLA website! My dilemma is regarding what to do with it! I would like it to be road legal, so I need to replace the bits that have been removed (but came with the bike), like the dynamo, number plates etc. But do I replace everything and return it to a Roadster status? Or do I keep it as a "race trim" bike? Obviously I would need to repaint the tanks and give it a good clean up, but is it legal to ride a bike without a primary / secondary chainguard? Im torn, because I have looked up pictures of factory produced Manx's from this era and they look pretty much the same as the road going Inters. Or do I keep it as it is in "rat" condition?
More oddities
- that front brake looks like a roadster iron half-width hub with a Manx sls brake plate (it looks like alloy, not magnesium) fitted to it. But Norton did not do an iron 8" front hub then. Is it 7" or 8"? Curiouser and curiouser. The first Manxes got iron rear hubs.
The cylinder barrel is definitely Manx, not an alloy International one.
It's a lot tidier than you suggested earlier. I would suggest sorting out its obvious defects and go for a ride. It probably needs a rear chainguard, functional lights (if you go all-LED, a battery only will do for a few hours' night riding...) and a registration plate holder.
It looks almost good to go…
Footrests are a possible issue. Left side is on the rear set lug, with rear set brake lever. So it either stays there, or move it forward and you need a standard brake lever.
The right side rest seems to be missing. If you put it on the rear lug, you'll need to sort out the kick-start. The gear lever is set for a forward footrest which then allows the kick-start to stay as it is.
Original tinware (primary…
Original tinware (primary chain case, chainguard) will be hard to find. It might be worth approaching one of the restorers first. Lots run with only the top cover on the primary. It looks hazardous...keep fingers away and wear decent boots - and don't get your trousers caught...
Rear chainguard protects you from a chain break, and protects the machine from chain lube being flung everywhere.
It would be a shame to keep it off the road for want of the correct tinware. Beyond that it's your call. Summer is (we hope) approaching. Not the best time to have the bike off the road.
Dynamo would have been removed for racing. LED lights mean you now longer really need it just to get home late. Some riders do big mileages with total loss LED lighting.
I'm lazy - I'd add red coachlines inside the black on the tank, and some proper Norton transfers, add a top chainguard and get it on the road, sort out footpegs and see how it behaves. Then you'll find out if it's mechanically sound, or if it needs mechanical work. Next winter will be the time to do the complicated things.
The only thing I would add
is to ease out those rusty front engine bolts, clean them and put back with some grease.
If it goes like some of my…
If it goes like some of my efforts , now may be the only time you get to ride it. All too easy to pull apart and create another basket case. Change oils ,do some fetling and safety inspections and get some riding in. You will soon find enough to do.
Parts identification, FYI.
Hi William,
I thought you may (or not) want more observations on your new aquisition. I believe your frame is a later replacement as it has the later "V" section plunger suspension castings which were not in general use until the 1950 season. You might see earlier bikes that have this shape, but these have been modified individually. All the other features pertain to the 1947 type frame. This may be the reason why there is not the correct number stamped on the frame.
If the engine number has been removed, it may be possible to find trace stress pressure marks by chemical identifying process, although that's probably a step too far. These crankcases were used from 1936 until 1947 and the big fin head and barrel from 1939. The number 9326 on the frame would equally be a 1939 350 engine number as they had their own number series pre-war.
Paul is correct regarding the front hub. This is a 7 inch iron hub as used on racing Internationals from 1934 to '36 before the introduction of the 8 inch conical hub for 1937. The hub is finned for cooling and slightly wider than the road spec type. The aluminium brake plate is correct and has magnesium brake shoes which have forked ends and pivot on a single spindle.
The petrol tank looks to be a 1950 DOHC aluminium type and the clutch and brake pedal are the correct Manx items. You will need to get some Norton books with photos of original machines if you want to make it a race bike, or build the bike with what you have for the road.
If you have got a V5c, I wouldn't bother chasing the numbers too much.
The primary chain appears to…
The primary chain appears to have little or no slack. Not good for engine or box bearings.Check the Box fixings are ok. My 36 bike had some poor substitutes that allowed the box to pull back and did some mischief to the main bearings.
Also check primary slack…
Also check primary slack when fully warm. Anyway on later Manx. On the one I now own, chain broke at last lap in -63 Junior TT.
Observations….
Thank you for posing this article, the responders are every knowledgable and we get to learn a bit more about the development of the Norton.
As you are bike savvy, (you must be if you are a Velo man… :-). ) you will already be aware of the required adjustments; both chains are well tight and the rear spindle nuts not home. The rear brake return spring needs to be set the adjuster setup is a bit unusual for me, it limits the amount of pressure you can apply but in off-road use that may be an advantage.
The frame has an Andre damper anchor plate, which I thought was dropped by 1950? The bars look to be Triumph TR style, whatever they are a good shape for off-road.
As Richard says the front brake would be pre 37 and the shoes would be 1.5” wide. I guess you have a collection of bits that came with the machine as some of it is not consistent with the current build state. Single feed banjo with twin tap tank. Mag Dyno but no regulator, (dynamo drive plated off).
Your fuel enrichment device on the carb is locked off to a fixed position. It works opposite to a choke but acts on the primary circuit not strangling the air flow. It’s a 1938 version of the 10TT carb.
It has its own story which you should try and investigate, it’s far more interesting than a factory finished example. The pegs and levers are as they should be though as per David’s comment kickstart will me an issue. Norton did a folding foot peg for this scenario but you can easily fashion one from a pillion peg.
It is a nice machine and look forward to hear of your progress with it
Best regards
Further information
Thanks for all of the very helpful and information and observations to date. I have spoken to the chap who previously owned it and the history is, as far as he can remember, as follows. He bought the machine in 1962 from a garage in Bridgwater. It was a road going machine that had been modified for racing during its previous life. It would appear that the chap who raced it actually rode it to Brands Hatch, removed the road legal bits and raced around the circuit, replacing the bits afterwards and riding home! Anyway, the bike was non standard even then. It had clip on handlebars, so the upper fork shrouds were missing, and Inter style rear mudguard to take a numberplate.
Shortly after buying it the oil pump / crank case split and, in those days, a repair was not possible by welding. So he got a pair of replacement crankcases from a "racing chap" in London (this would explain the ground off number) and had the bottom end rebuilt by Hamlins Motor Engineers in Bridgwater. He rode it for a few months and then got married. Money was tight, so the bike was mothballed. He had always been led to believe that the bike was a Manx and so, after many years, decided to "restore it" to some semblance of a Manx. He had, because they were damaged, thrown away the original crankcases, which had the original engine number on them, and "acquired" Manx front and rear mudguards, a set of Upper Fork Shrouds to take a headlight, fitted a Magdyno (he cant remember what he did with the BTH Mag!) and generally tinkered with it. He chucked away the old tinware as "being worthless!" He moved house in 1971, having not ridden it since 1963, and put it in the garage. Apart from occasionally starting it up (about once a year) and riding it up and down the lane, the bike has not been ridden properly since 1963! He is now 84 and realises it was never going to be done properly, so he sold it to me!
I have now had a good look at it, guided by your wisdom. In light of the crankcase issue I have concluded that the rest of the engine is actually original to the bike, and, given the frame number it is a 1947 frame. However, there is a mystery with the forks. I base this on the fact that the "lock Stops" on the frame do not line up with the Lock Quadrant on the Roadholders. I also suspect that the engine number for the remains of this engine would have been 9326 as well, as per the numbering system, and that dates it as a 1947 engine.
I have also noted your comments regarding the footrests / kickstart issue. I have looked at the roadgoing Inters and the footrests appear to mount to the frame downtube just behind the engine. The frame that I have has no such mounting points. The only possible location for them, with a serrated mount, is the "rear set" lugs on the frame.
One other question. The bike has a "Road" upright gearbox. If I were to return it to original spec I believe that this should be a "Dolls Head" type. Looking at a parts book, am I right in thinking that the gearbox shell is common to all and that a Dolls Head outer case would bolt straight on? I'm not overly bothered about gear ratios, so have no plans to alter the "innards" of the box.
Given the majority of parts are actually Manx I am minded to "restore" it to Manx Racing condition, but obviously it will be a hybrid. It would be nice to get it up to a decent spec and complete the bikes journey through its life.
Your thoughts Gents?
Library, Brochure Book
If you take a look in there you will see yearly brochures of the models and can pick out some of the major changes. They are not always accurate but you get a feel for the differences. Hope this helps.
Regarding gearboxes
the so-called 'doll's head' is the pre-WW2 road gear-box. It had a round-ish cover over the positive stop mechanism, and the clutch quick-thread lifter arrangement was external. Post WW2, the gearbox outer cover was changed, so that the outer cover was oval and covered the positive stop, the clutch lifter and went around the kick starter as well. This is the gearbox you have, which I am guessing is a close-ratio International box.
If it has a high-ish first gear (27-14 tooth), and a HUGE jump to second, and then close 2-3-4 ratios, it's an Inter box. If so, converting to Manx spec means getting a race-type end cover (it keeps the doll's head look, and as far as I remember, kept the external clutch lifter) and a different first gear pair 25-17 tooth.
Just for a little extra confirmation, those Roadholder forks are Manx. The sliders are the early type with the mudguard stay bolts one above the other, directly above the lug for the Manx brake plate. It lacks the lug for a roadster front brake. FWIW the iron-lug frame Manxes kept this early Roadholder style fork slider right up to Featherbed Manx. Manx ones are forged, roadster are cast.
The first couple of years of road bikes (1946-48 ish) had a slider that looked just like this, with a lug for the roadster brakes as well (the Manx lug was not machined..) Should you be in need of a pre-fetherbed Manx slider, then an early road one will do at a pinch, machine the unused Manx lug, and cut off the road brake lug. My 1955 Dominator has the un-machined Manx brake lug, but '56 bikes did not.
Footrests - road Inters mounted them in the same way as any other road Norton, using a long stud passing between engine and gearbox. From memory the footrest arms are a little longer to move the rests backwards a little. Now there's a good idea, I should do that to my Dominator...... The road Inter frames came with extra lugs to mount the same footrests in the rear position as on a Manx. You do not get the fittings to use the front position on a Manx. You could get some Inter engine plates and a kit of footrest parts if you are really determined. You will need to change the brake pedal and gear lever as well.
A 1950 Norton Singles Parts book (Model 7 Dominator got a separate book) will be useful, that was the first one published by Norton post WW2. You may get lucky and find one on the net. Bruce Main-Smith used to do photocopies of such things. Should you be desperate, I have a '50 Singles parts book which could be photocopied. You should also get Norton's Maintenance Manual which covers the plunger International and early Manx. I just had a look in my copy, it has notes in it made by my father in 1954 or '5, with an annotation pointing out that Fig 4 on page 11 has an error - it shows 12 vernier holes on the inlet cam, same as the exhaust.
Just to add to Paul’s
Detailed information, the 1950 Spares manual is also available in the library section. Online version. I think the MagDyno is not correct for an Inter; it is tight cable advance and should be slack ( the manual cable is on the wrong side). But if you want to turn I into it’s Manx origins then Lucas or BTH magnetos were offered.
Enjoy!
More info.
Hi William,
Your gearbox with the small round access cover will most likely have standard gears which are preferable to the close ratios for every-day riding. The access cover was modified to the oval type for 1947. You can fit a non-kickstart racing end cover to your casing, but you will need a layshaft to suit.
The reason your lock stops don't line up is because you are missing the round chamfered edge stops that fit on the protruding bolts. The reason for these was that Norton used the same headstock as that used with girder forks and the round stops were a cheap solution. I think these are available from the NOC shop.
I have attached a scan of the parts book that will be the most suitable for your bike. Also there is some good info on Ken MacIntosh's website at www.postwarnorton.com
The gear ratios were stamped…
The gear ratios were stamped on the rear of the gearbox casings before the war. Both on Inter and the other road bikes. Post war I believe they only stamped the Inter, but might be wrong. It's worth a look.
If you have the Inter ratios, RGM sell the "Daytona" first gears. A higher first gear closes up the jump from 1 to 2 and makes it much more road friendly.
The Dommie version of malleable iron casting for the footrest hanger will fit. The actual Dommie peg is only a plain bar but it will unscrew to allow the proper footrest to be added.
Thank you all for your…
Thank you all for your expertise and comments. I have cleaned the Gearbox and found the following stamps:
N8001 10 cast into the shell, which I believe means that it is a post 1945 box (which fits with the 1947 date). It then has G16L46 stamped on it, which I assume is the Gearbox Number.
It also has, as David has noted, the Ratios stamped on it, but a repair has been made to the Top Lug and so one of the number stampings has been erased! What is legible is as follows :- 1.33 - 1, 1.77 - 1 and 1.1 - 1.
Reference to the technical data in the NOC Technical section gives the ratios for Standard, Close and Wide. Using those figures gives me the 1.33 - 1 and the 1.1 -1. So I am working on the basis that this is an Inter Box with standard road gears.
From the data chart that gearbox should have the following ratios:- 1st - 0.44 - 1, 2nd - 0.75 - 1, 3rd - 1.1 - 1 and 4th 1.33 - 1. So my case is stamped with the 3rd and 4th gear ratios which appear to be correct. But what on earth is the 1.77 - 1 stamping all about? I know that either the first or second gear ratio stamping is missing due to the repair mentioned, but the other one makes no sense at all if it is either the first or second gear ratio. The stampings look to be factory, as they all match and are in the correct position!
Your wisdom would be appreciated.
Thanks in advance.
Nice Project
Hi William
Great looking bike, and will make for an interesting project.
if needing any inspiration attached is my road registered Manx/Inter special built in 1951, pre war engine, late 40’s double knocker Manx frame.
as many on here have said get it all safe and out on the road.
regards
Simon
1.77 is the bottom gear for…
1.77 is the bottom gear for non- kick-start Inter.
identifying gearboxes
The gearbox on Simon Carver's bike is the Doll's head box. This was used from 1934 when the Sturmey Archer gearbox became the Norton box, made by Burman. This version continued until some time in 1947, when the slightly improved 'vertical' box was introduced. It had a larger vertical oval cover encompasing the positive stop, clutch lifter and kick start boss. The kick start lever return spring remained under a removable cover. This is the gearbox on William Monteith's machine.
The racing gearbox, as on Manx and Clubman's International had essentially the same end-cover as the Doll's Head box, but lacking the kick starter boss area. Note that the clutch lifter arm is external. This end cover was used on all plunger Manx machines. The advantage of a proper Manx gearbox outer cover is that the layshaft ran in a ball bearing set in the gearbox end cover, instead of a bush inside that kick start shaft.
The featherbed Manx adopted a version of the 'horizontal', or 'laydown' box - also made by Burman for Norton. I suspect that it was machined from the same castings as the road box.
An interesting update! (and a question)
Well, work on the bike has proceeded apace. The bike has been stripped and the frame sent away for bead blasting and acid etching prior to being Stove enamelled.
In its etched state I managed to find the original frame number, and this has chucked up some interesting anomalies. The number in the log book is shown as 9326. This is also stamped very neatly on the Steering headstock, right where the frame number should be. I had also previously found the number 13166, also very neatly stamped, under the saddle post. Contributors to this thread have identified that number as the casting number. I can now almost safely say that the number 9326 is also the casting number for the headstock! That's because I have now found the original frame number!
This was actually stamped on the lug for the front engine mount! And on first inspection it shows the corresponding frame number to the engine number in the log book! Great, we are making progress. So I took a picture of it. (below) When I enlarged the picture I got a bit of a shock. The number is actually an overstamp! The original "factory" stamp, (much neater) is clearly visible. And this is what I have got.
Original number: B11M 9970
Current Number: B10M 10096
Reference to the dating chart shows that the frame is actually a 30M 500 Manx frame. This is also backed up by the fact that virtually every lug on this machine has the word "Racing" cast into them (pictured below). Not visible before, these are very clearly visible now! So I actually have a 1947 Manx 500 frame that has been subsequently fitted with a 1947 40M engine and the frame overstamped accordingly. I now know that the Log Book must be wrong as well!
In other news, I have also sourced a reconditioned BTH KD1TT Magneto, so the incorrect Magdyno can be removed.
And now the question. The bike has steel wheel rims and they are hand painted silver and in poor condition. For a 1947 Manx machine what would be the correct rims to replace them? The front is a WM1 21" rim with 40 spokes, 20 per side. The rear is a WM2 20", again with 40 spokes. Should this bike have Chrome rims, Black painted rims (with or without the red pinstripe) or Alloy Rims?
You really are a mine of knowledge and I look forward to your thoughts on these developments. Thank you.
For details of finishes, you…
For details of finishes, you need Bacon's 'Norton Singles'
Rims would be chrome with black centres and red coach lines.
But although 21" ribbed front tyre is still made by Avon (unless they stop later this year....) the 20" rear tyre is not so easily found (except for off road machines). You might be better off with 19" rear and 3.5 section tyre than the correct 20" rear and 3.25 tyre. The Featherbeds all had 19" at each end. So check if you can find the correct tyre before you put time and money into wheel rims.
The lug in your second picture has the scallop shape cutaway of racing frames. Saving weight and perhaps improving brazing penetration inspection.
99 dominator identification
Hello NOC I bought a 99 dominator in Birmingham 10 years ago, I drove with many miles without problem. But after a engine trouble I opened it . I thought it was a 600cc but not it's a 500cc
Can you explain this transformation to me where is it original ? N° frame M14 73201 and N° engine L14 69013 and on the rear crankcase 99 1284
Thank you all
There is no dimensional…
There is no dimensional difference between 88 and 99 crankcases ,cylinder heads and connecting rods. Its only the cylinders, pistons ,cranks,pushrods, carbs and gearing that are different. This makes it easy to swap whole engines and build mongrel engines . No one at an Mot station or Tax office would have a clue that changes have been made . It was usually done to avoid expense and use locally found spares. Just live with it. But be aware that some mixtures will need modified parts to avoid mechanical mayhem. If you have such an issue you would know all about it by now !.
http://classicenglishbikes.com/tech_file/norton.html
Yours looks about 1947 vintage. Someone has enjoyed a nice machine. 10M on the frame declares a Model 40 (350cc).
Looks like magnesium cases, consistent with Manx type.
Looks like a nice used machine... try keep it that way
J
