Dan, I seem to remember ne…
Thanks Neil, Having done a…
Thanks Neil, Having done a bit of googling, it seems that you have to ream the small end bush to fit a JP piston, that's actually really good if your small end is worn, mine isn't and the seller didn't point this out to me. Which is annoying. I'll give them a ring later, but having fitted the rings and one clip, I'm, perhaps wrongly, expecting a fight! I knew that JP and GPM pistons are heavier than standard, but my bike was fitted with a high comp piston that had been badly adapted and I didn't trust ... The valve cut outs were too deep, and that was much heavier than the JP, and I don't know what piston it was balanced with originally I'll try a GPM piston and andsee how that fits. I don't want to ream the small end unless I have to. And of course if anyone can find a +40 heptolite piston, let me know!
I weighed some old Hepolit…
I rang RGM who were as alw…
I rang RGM who were as always helpful and offered me a refund even though I'd fitted the rings. So will order a GPM after I've got someone to measure the GPM pin!
I weighed these two tonigh…
I weighed these two tonight, the heptolite is 428 gms and the JP is 467gms, interestingly most of the difference is in the weight of the pin, the JP pin is about 40gms heavier than the other
.[IMG]http://i29.photobucket.com/albums/c264/deperatedan/image.jpg1_zpsbrec3q15.jpg[/IMG]
Dan
Hi Dan, Your old piston is…
Hi Dan,
Your old piston is a pre 1948 16H type which is quite often used in ES2 engines.The skirt length has to be reduced and you need vavle cut-aways which I see has been done on the old one, although they look a bit too much to me. If you don't have any spacers under the barrel the compression ratio will be about 8.5 to 1, so you will notice quite a drop in performance if you go down to the original 6.7 to 1 and you will have to advance your ignition as well. There should be plenty of 16H pistons around if you want to stick to what you have. ATB Richard.
Hi Richard, the PO did the…
Hi Richard, the PO did the work on the 16h piston, and I'm not using it because I think he has taken too much meat out when he cut the valve pockets with what looks like a dremmel! He trimmed the buttom of the skirt and the top edge with a file., if you zoom in you can see the marks, its not very pretty. I d have preferred to use a milling machine.
My bike is in trials trim which is why I want the standard lower comp piston. If I decide to go to a high comp I'll go prob with a BSA and do it properly!
Dan
hi dan Interesting topic a…
hi dan
Interesting topic about jp pistons,The chances are that your replacement piston has a metric gudgeon pin instead of an imperial size it would have had originally ,Companies are phasing out imperial sized parts and substituting easier to make metric parts as they call the imperial system ( non prefered size) this happens often in engineering and can be a pain in the ar-e
eg .6869/.6867 standard pin size on a commando would now be 17.5mm which is roughly .002/.0022 thou larger and thats why you had to ream your s/e bush
I would also like to pass-on that jp pistons need more cylinder/piston clearance to stop them from seizing
check out the M.G owners forum
steve
Interesting, I haven't re…
Interesting, I haven't reamed the bush yet, I'm hoping that a GPM piston has the right sized pin.
dan
Close up of DIY piston poc…
Close up of DIY piston pocket!
[IMG]http://i29.photobucket.com/albums/c264/deperatedan/image.jpg1_zpseaxzaibs.jpg[/IMG]
Previously Dan Field wrote…
Hi Dan,
Do you know what make of blindfold the PO used ? I did one of these when I was 18 and made a better job !
I had a good look at Nettl…
I had a good look at Nettley for a heptolite piston and sadly could only find a +20 which was seriously abused! However I did find a complete set of pre featherbed engine plates with gearbox adjuster and a good set of long roadholders . I also found a recon AMC gearbox but had spent all my money by then! So I have ordered a GPM and will report back.
My GPM arrived today ... q…
My GPM arrived today ... quick delivery by Andover Norton, sadly they too seem to have a larger gudgeon pin, so the hunt for a + 0.040 heptolite piston continues, before I decide wether to ream or go for a 16h piston.
incidentially the GPM is about 10gms heavier than the JP on the kitchen scales, the GPM pin is internally tapered, like the heptolite, The JP isn't so it could be made even lighter.
Hi Dan You said you found…
Hi Dan
You said you found a set of pre f/bed engine plates. Did you buy them?
Were they for a single with Norton AMC box?
Good luck with the piston, personally I think the JP piston was a good route to take and with some weight removed then perfect..
Previously Neil Wyatt wrot…
Previously Neil Wyatt wrote:
Hi Dan
Hi Neil,
yes they were for an AMC gearbox'd single. It was a complete set, both sides (£60) and the gearbox adjuster with mounting bolt (£15) bit expensive but I couldn't see me finding another set so put my hand in my pocket!
Did you get your set? I have a spare RHS now but it is just the plate with no footrest mount (available from RGM).
Let me know if you need any photos.
ref the piston, two phone calls tomorrow, one to my local engineer ( Dave Massam, or Cox and Turner) about reaming and one to Mike Pemberton about what piston to use and what he offers, but what I don't know is what difference a 16h makes to the performance of an Es2
dan
Hi again Dan, I fitted a p…
Hi again Dan,
I fitted a pre1948 16H piston to my 1948 model 18 way back in 1972. I was 18 years old then and the old engine was getting tired of all the thrashing it was getting and struggled to hit 75 mph.I cut the bottom of the skirt off and made valve pockets, all with hand tools and also streamlined the inlet port and double ground the head joint. This pushed the compession up to about 8.75 to 1 which was right on the limit for a cast iron head but leaded 4 star just about coped with it. When used with a Brooklands can and a slightly larger main jet and a belmouth this put 10 mph on the top speed with acceleration to match. If I was doing the same today I would fit a 1/16th inch spacer under the barrel to reduce the compression, although you will be O.K. with an alloy head all usingsuper unleaded. The best piston for your situation would be a 1948-54 16H which has a lower dome than the earlier type which gives about 7.5 to 1. This is the split skirt type and will need shortening like the earlier type.
ATB, Richard.
Dan, Regards the pre/fbed…
Dan, Regards the pre/fbed plates, an overseas Norton man is helping me. Only the postage that might be an issue. I am very grateful for this after several leads that came to nothing .I'm confident and so going to start the project once I have successfully had my trial Rattle run to the coast on my 650. I'll tell you about that on another thread. It might be tomorrow if we keep the high pressure.
Do tell how you got on with that piston, my money is still on the JP, they are well made but slightly heavy.
Well I thought I'd be getting my bike back together this afternoon, having bought a new + 40th JP piston from RGM, .... the old piston pin slid out with a bit of gentle heat as you would expect. I cleaned up the case faces and made sure the oil ways were clear, fitted a new gasket (with grease not loss of blue gloop!) I fitted the new rings and one circlip and set about fitting the new piston, sadly I couldn't get it to fit, the pin is a nice fit in the piston, but impossible to fit into the rod. I tried some serious heat and that didn't help either. Having taken if off again I measured the two pins ( the piston I was replacing was a heptolite) the JP pin is at least 0.003/4 mm bigger than the original. So I seem to be left with trying to get my money back or trailering the bike to an engineer and having the bush reamed. Is this a common problem with JP Pistons? Are GPM any better? I had no such problem with the Jubilee! Dan
G'day Dan,
A suitable adjustable reamer should assist you and a really must have in the tool cupboard, plus you will be able to achieve a perfect fit!
Rgds Steve
Steve, my engineer says th…
Steve, my engineer says the trouble is a new hand reamer will tend to grab, Looking for a heptolite piston first!
I have been following this…
I have been following this thread with interest and would like to say a couple of things that I have done successfully in the same situation, if the piston assemblyis too heavy, it can be lightened by boreing out the gudgeon pin to rapidly lose some weight, though, a littlecomparisonof the wall thickness of same outside diameter of lighter pins is advisable. This is on top of reducing piston skirt thickness.
To ream out the bronze gudgeon pin bush, I use an adjustable reamer taking manylight cuts with no problem. Insert the reamer through bush, and gradually expand in positionafter a couple of turns.You will need a pin in the bushclearance of .001" to .0015", or an easy slide fit with the slightest percievable rock. Too tight and it will starve of oil when running.
Sharp tools are required for brass/bronze, as a dull edge will suddenly dig in as excess pressure is exerted to get it to start to cut, in my experiance.
Regards,
Must agree with Paul - usi…
Must agree with Paul - using a reamer is not too difficult, only mildly terrifying the very first time. If I can ream a small end successfully, anyone can...
Previously Gordon Johnston…
I have found a Heptolite ES2 piston, it's on it's way from oop North (wasn't cheap tho!) assuming it fits I'll be using that but will photograph and weigh all 4 as a reference for others!
Dan, I seem to remember needing to have a new little end bush making to fit my AP / JP piston, but that's not why I'm writing.
These are good quality pistons but I think you will find it heavier than the original. Your bike will run fine with it but you might just find the engine slightly more lumpy. I'm happy with it in my poor man's Manx but if I had bothered to weigh the piston against the original, I would have removed a tiny amount of metal.
Hope this helps.
