Dished Pistons
Atlas dished (concave) pistons……are they available? I need a std pair for a rebuild.
Some time ago I saw a foreign site (Dutch?) advertising obscure pistons, including Atlas dished ones, at considerable expense.
My Atlas is running Commando pistons as that's all I could get hold of at the time. They work, but I would be happier with a lower compression ratio.
Might be a bit big but I nearly bought a dished piston (19S) for my big bore ES2 about 18 years ago from Bantam John.
Bantam John bought up all Martin Bratby's piston business.
I may have a contact with some that need valve recesses to be machined to make them a pair   , give me a few days to get in contact
Occasionally a single dished Atlas piston turns up on EBay, but you could wait a long time to get a pair together… My Atlas also runs on Commando ones, but has a 2mm compression plate fitted under the barrel, which reduces the compression ratio a little. I think some people fit two head gaskets for the same reason.
I have some brand new complete sets of standard Hepolite Atlas 7.6.1 pistons.
Hi Anthony, could I please purchase a pair from you?
My email is chris@exmoorflyfishing.com if you would like to contact me with a price etc etc
Many thanks
Chris
Hi Anthony, I would like a pair of +.020" Atlas pistons if you have some available?
Many thanks, hopefully.
I will have to go and have a look to see if i have a pair of +20 Atlas pistons.
