I am looking for the torque settings for the crankshaft nut, camshaft nut, tensioner nuts, and the oil pump nuts for a 65 Atlas.
Thank you in advance
Heavyweight Twins Compendium
There is a very comprehensive set of Dominator torque settings to be found within the Heavy Twins Compendium.....page 262 on.
The camshaft being keyed only needs around 50ft lbs for its nut.
Heavy Twins compendium?
Phil, can you tell me what that is, please?
BTW the camshaft nut torque figure 50lb rings a bell
To view the compendium go to…
To view the compendium go to the top of the home page , Hold cursor over technical ,then click heavy twins, then click on the illustrations of the compendium at the bottom of the page . One is general stuff and the other electrical. And a big thankyou to Phil and the rest of the guys who put it all together for us.
Compendium appreciation
I bought the singles and twin versions and I confess I read a section every day. Absolute mine of information. And yes folks it’s there at the top of the page Free! Great asset for our members…
the crankshaft nut should be 75lb, oil pump nuts 12lb. Camshaft tensioner nuts probably the same 12lb. I didn't find a figure for the camshaft sprocket nut
