Navigator Pistons
Dear all,
I am in the process of stripping down my May 1964 'late' Navigator engine and discovered three very interesting things:
First, it has no spigots on the barrels so Plumstead had definitely stopped including them by then.
Second, although it is obvious that the crankcases, primary side (apart from the cover) and gearbox have never been apart the heads have been off at some point although the pistons are standard and there is no obvious sign of bore wear despite it's indicated 32,000 miles (a quick measurement suggests a maximum of 63.02mm).
Third, and more intriguing the standard pistons aren't the 'Split Skirt' Hepolite pistons I had expected.  They have solid skirts with slots behind the oil scrapper rings and had the 'wire' gudgeon pin retainers rather than the 'circlips' I have always seen used by Hepolite.   I haven't investigated in great depth yet but there seems to be differences in the size of the piston rings compared to my spare set of new Std Hepolite rings.   The pistons are in excellent condition with no signs of wear or scuffing on the thrust faces so I intend to continue using them.  I have attached a photo to show the difference compraed to a new + 20 thou Heplolite piston with split skirts.   The only identifying mark is the numbers 63 011 punched into the piston crown - certainly not the Norton or Hepolite part number (another photo attached).
Can anyone answer the following questions:
1.  Are my pistons 'later' Hepolite pistons modified to address the piston cracking problem documented by Andy S and others?
2.  Are they a different manufacturer's piston - perhaps AE Edmund Walker? - if not who?  I seem to remember buying a set made by them for my Jubilee in the late 70s.
3.  If they aren't Hepolite pistons is it safe to use a set of new Standard Hepolite rings if they fit with my existing pistons?
Looking forward to hearing the combined wisdom!
Cheers.   Nick
Probably a silly question,   why change the rings?.The piston does not show signs of blowby. Are the bores rusty?.
I once owned Navigator DEL28C. Registered with Dorchester police in 1965, one of two ordered for senior police transport to incidents. 15,000miles and good order when I bought it. I really liked it.
While I had the bike in 1969 the bike was stolen, chased by the police, bike and the villain pulled out of a hedge in a council estate. I think the twist grip got jammed fully open at the crash. Quite an experience listening to the chase live at the radio room of Chicheseter police HQ.
Thereafter the bike always smoked a bit on the right. 18 months later, after a run to blow the cobwebs, the right hand piston crown left the rest of the piston.
The build was a late spigot-less one like yours Nick.
My advice to you would be to restore as you found it. So many of these bikes were ruined by unnecessary maintenance. Try very hard to get another composite one piece gasket like you took off. Old Navigator gasket sets surface on eBay with the composite head gasket included.
You should see the piston manufacturer markings (AE ?) inside the piston, part of the forging/casting. Not on the top. I believe in mid 60's Hepworth, later Hepworth and Grandage, were part of the AE group. We still have AE turbine components in Bradford, who in the '70's were Hepworth and Grandage, making forged gas turbine blades. More profitable than motorbike pistons.
Put your pistons back as you found them. Unlike Robert I'd recommend you buy new piston rings . Also new retaining rings. Did you mark L/R and front/back on the pistons as you removed them? If not, anther good reason to put in new rings. Your rings look like the standard ring widths.
It is so annoying to re-use piston rings and find your bike becomes a smoker. I know.
All the best
I believe DEL28C is still around and looking much better than when I had it. About 10 years ago the proud owner's photo showed it had lost all it's patina (My blue and black hammerite over the rusty bits) and been fully civilianised. (Lost it's tank with radio cut-out. A4 size and very useful for maps and stuff.)
Back in the days when rings and oversize pistons /spare barrels were  readilly availiable  I would often pop in some new rings  without a qualm . Sometimes without even a hone ,just a good rough up with some emery and a scrape round the top to remove any step.Hard daily use and  cheap oil meant that running in did not take too long. Some new rings are now so hard that  a good hone or rebore is needed to bed them in if you are to avoid  a long  proccess . Our Atlas is now running well with a hone and new rings on the old pistons , the old rings were ruined by my lad never changing the oil resulting in heavy  wear ,ring flutter and oil pumping. Took a while to find some suitable rings. All  unnecessary work with good maintenance !.
...and good luck finding new circlips...as Bernal Osborne wrote in my copy of Modern Motorcycle Maintenance ... "avoid unnecessary fettling!!!!:
Not sure why David thinks these will be a problem.
In the NOC shop part number 21581.
Or if you want something the same as before, this pack of 5 from Simply Bearings should do the job. Check the dimensions yourself but I think these will do.
RSR14MM Round Snap Ring 14mm Nominal Shaft Diameters Simply Bearings Ltd
Thanks everyone for advice so far and thanks Peter,
I’ve already ordered 4 wire retainers from the NOC shop!   In your experience did Hepolite introduce a modified Navigator piston without a split skirt after the history of failures or is my very sketchy memory correct about AE Edmund Walker producing Lightweight pistons?   Did Norton vary suppliers?   All the evidence is mine are original from build!  Intriguing stuff!
nick
If its not smoking now plus the ring gaps are not excessive then put the old rings back in, you save a hone and the running in period.
It does seem that the lightweights are  poorly served with  pistons and cylinders , The quality of replacements has been discussed  in previous  posts . If there is any hiccup with any  new rings and you are then  faced with a rebore and new O/S pistons your bike could be in a basket  for a long  time . Take extra care  with your good  orriginal stuff  . You are lucky to have it.
Hi Nick,
Edmunds Walker were not taken into the AE group of companies until 1968. Hepworth was one of the three companies in at the start of Associated Engineering in 1947, along with Wellworthy Piston rings and British Piston Ring.  Hepolite was a brand name of AE in the 60's. I don't know if EW made pistons, but AE already had a piston manufacturer in the family.
You seem to have the living evidence that Navigator pistons came in Electra style, with oil holes under the wide ring groove.
The club have an old print of Norton drawing 24708. Electra piston. Sadly I don't know of any Navigator piston print.
Drawing date 27/7/62 and this print to toolroom at Plumstead 1/3/63.
Some of the notes catch my eye.
"Based on H&G Drg No. X16025 but increased diameter"
"See later H&G piston Drg X16104 drawn 20/9/62"
"Use Navigator G P". "H&G request different gudgeon pin"
"440cc, CR 8.25:1. Stroke 58mm. Max RPM 7000, Est max power 24 BHP. Est explosion pressure 1,100 psi."
All this suggests that H&G were the design authority for the piston assembly and the Norton drawing was produced for inspection purposes. The drawing shows the piston with 8 oil holes in and 6 below the lower ring groove. Solid skirt.
Was X16025 a Navigator piston design similar to Electra?
Was X16104 a later drawing of this Navigator piston? Did one of these H&G designs go into production?
Norton may have slid a change of piston design into Navigator production without changing the part number. No parts lists and build schedules to alter and it could be seen as interchangeable with split skirt design. I don't suppose Navigator documentation had priority in the AMC design office. I'm sure it would have been done to address piston issues.
Any AE numbers like these above cast/forged into the piston inner surface?
Fascinating.
Fascinating indeed, Peter - giving much food for thought.
24708 is indeed Norton's P/N for the Electra piston (I forget the H&G P/N now alas) but those dimensions are interesting:
Production Electras were 66 x 56 mm, yielding a swept volume of 383.2 cc
Joe Berliner's prototypes were 66 x 58 mm, giving 396.9 cc
440 cc, 58 mm stroke imply a bore of 69.5 mm! Hard if not impossible to achieve without changing the piston / rod / journal spacing in my view. And cost would doubtless have precluded that.
Concur absolutely that H&G were the design authority, which is why it is always their P/N and not Norton's which was stamped on the crown. [Applies to all five known types of lightweight piston, and I suspect to the big twins too.]
Looking at the squared off (unchamfered) gudgeon pin bores, I am unable to attribute NIck's oddball pistons to H&G, who knew better than that. I think it far more likely that they are aftermarket pistons from one such as JP Pistons of Australia. The '63 xxx' stamping on the crown also suggests the use of a 'universal' 63 mm blank which has been finish machined to the required dimensions. As you say to Nick, inspection of the inside of the skirt will confirm that.
If they are aftermarket items, they are likely to be heavier - the JPs that I bought as pares for my Electra, but could never bring myself to fit, certainly were. It would be worth checking ...
Even so, it is interesting to ponder whether H&G might have been considering a change to the 'pepper pot drilled' design as adopted on the Electra? Even the later Navi pistons (15418) would crack eventually with spirited riding, though they last much better than the originals
400 cc the capacity on Electra piston drawing 24708. My error.
You make a great contribution on the lightweight piston story. Told as someone who seems to have a fair bit of background - I suspect.
Thanks Peter
Some good stuff written above – thanks Peter (& Roger)!!
Nicks pistons at the top of the thread:
The piston on the left is unusual, and looks marginally taller than the (usual) piston on the right, and you can see that it sticks up a little in his photo of the barrel. The 63 xxx makes it look like a standard 63mm piston, as Peter suggests.
Bear in mind, that spigotless barrels (introduced around Oct '63) were actually 2mm taller than spigotted barrels – as the spigots had to be machined. You will notice (although Nick does not show us) that the matching heads will have had 2mm skimmed off them – like Electra heads.
My Navi is number 106840 and uses spigotted heads (I've owned her since 1972) and I know that Navi 106979 (only 150 numbers after mine) defo had spigotless barrels from new. And, as it happens, I know Nicks bike is only about 50 numbers up from mine – so was made around the same time as well! So we near enough know when the change occurred.
If Nick uses his 'special' pistons, he will have two advantages over me: 1) He will have slightly higher compression, and 2) The top of his piston is less likely to come off!
The Jury, however, is out on circlips. The snap rings Peter shows us RSR14MM Round Snap Ring 14mm Nominal Shaft Diameters Simply Bearings Ltd are for fitting to shafts, with a groove. Are they really suited to fitting in an outer groove?
There is a secondary problem in using snap rings as circlips - their removal!
I just copied a Picture off Andover Nortons Website for you, showing a Commando piston using snap rings - note the cutouts to enable removal of said snap rings.
note snap ring removal grooves
Note Snap Ring removal grooves
Hi Andy, Peter, Roger, Robert, John and David,
Thank you for all your sage advice and apologies for the delay in reply but it has been a full on week and only now had a chance to get out to the workshop to investigate further.   Following comments and information on the engine, barrels, heads and intriguing pistons:
1.  Andy as you said, my engine number is 19/106892/P so as your is 19/106840/P it is only 52 after yours.   I have attached pics to show how the heads have no groves and the barrels have no spigots.  The bores are definitely Std at 63mm, show no obvious wear ridge or damage to the bores and have not been relined.   From my memory of Jubilee heads which have quite a raised area around the push-rod tunnels and combustion chambers, mine seem to have been machined a good couple of mm more tlo remove the spigot locating grove round the combustion chamber so your comment about compression ratio being higher is probably right, particularly as the pistons project about a mm above the tops of the barrels at TDC.
2.  On closer inspection the pistons have two slits machined either side of the gudgeon pins into the oil scraper ring slot to allow oil to pass up inside the piston, pass through the skirt and feed the back of the oil scraper ring.  Each end of the slot is drilled, I presume to avoid this being an area from which a crack could propogate.   I have attached a photo to show the hole and a short section of the grove.    A very different solution to the Electra pistons which Peter says had 8 holes drilled behind the oild scraper rings and 6 below.
3.   I have attached a photos looking inside the piston towards the crown showing the two slots (the thick silver lines on the crown either side of the gudgeon pin).  The second photo shows the only other manufacturers markings - the number 1091.
4.   I have compared the piston rings with my spare set of new Std Hepolite rings and there are significant differences.    I have not dared remove the rings for fear of breaking one and not being able to source replacements!    The two compression rings are thinner than the Hepolite rings which won't fit.   If you look very closely at the first photo the second ring is 'stepped' which the Hepolite ring isn't.   The oil control rings have different slots in them although the same thickness.   Perhaps evident pointing towards JP pistons?
5.   Knowing that JP pistons are reputably heavier than original pistons I weighed the ones out of the engine which both weighed 272 grams and then my set of +20 thou Hepolite pistons which weighed 235.5 grms and 236 grms.  Does this points to them being JP pistons?   has anyone got a pair that they can weigh as a comparrision?
6.   If they are JP pistons why did a previous owner replace them?    There is no sign of bore wear, damage or overheating.  The only evidence is a very small hint of hot gas erosion on the left hand head which might be a sign of a blown head gasket.   The heads have definitly been off and new original head gaskets used - luckily I have a new, original composite one ready for the rebuild!
All in all an intriguing discovery - why did a previous owner change the pistons and who are the replacement pistons made by!    If anyone can unravel the mystery then please let me know!
As for the pictures I will have to load them one at a time because the 5 MB limit!
Piston showing oil grove behind oil scraper ring with drilled end and second, thin, stepped  compression ring.
My experience with Navigator pistons, when I was rebuilding my 1963 Navigator engine the rings were damaged due to the bike coming to me in a number of boxes (a real basket case) the bore and piston are in good condition at 0.020” oversize and the piston is of the same type as shown in Nicholas Clark's photos, I ordered a new set of rings from NOC and the size was completely out with the rings thickness being to thin, With the help of Brian North (engine reconditioner in Cardiff) we identified that “Cords” rings had been fitted, Brian has a good stock of “Cords” rings and we found that rings for a "1936 Ford Utility V8 Vedette" are very close to the required size. All I needed todo was widen the groove for one of the rings and deepen the Oil ring groove to give the correct internal radial clearance (ring to piston) on both pistons, all machining done on my Myford Lathe at home. Bike as now done over 200 miles with the first 100 using running in oil. I have a cartridge oil filter fitted which I plan to change at 500 miles.
Download Irfanview, open up the picture and then select save, under 'set size as' put in either 0.5mb or 1 mb and then save, agree to overwrite or rename it as say name compressed. Now you have smaller pics you can post.
https://www.irfanview.com/
I had hoped to unearth the photos of the JP Electra pistons that I passed on, unused ... but seemingly that was three computers ago, and all I have retained is the last two! So no joy, sorry.
I will still have < somewhere > my record of their weight, but I won't be able to conjure that up quickly, however. I do however recall clearly that they were more than 20g overweight, and possibly as much as 30g.
I have just measured a NOS STD H&G piston (15418) at 242g with gudgeon in and rings but not circlips (none readily to hand).
As a by-the-by, I once bought and used a pair of later-type Navi pistons (+010) bearing P/N 15625 rather than 15418, and likewise branded AE. No idea what the difference is, they were visually identical. The PN was stamped on the crown and cast into the skirt in usual fashion. Most that I have encountered in 40+ years of Navi ownership are 15418 though, other than the fragile 15110 originals (of which few now survive).
Best regards, Roger
Thanks for your various comments Steven, John and Roger, all very useful - given Roger's recollection that his JR pistons were about 20 or 30 gms over weight and the similar disparity between my NOS Hepolite +20 thou pistons and the mystery Std ones in my engine I do wonder if that is what I have here!
Roger, did your JP pistons have 'wire' circlips or proper circlips that Hepolite use?   Are the part numbers you are quoting H&G part numbers?   My late Navigator parts list shows a Std Piston complete with gudgeon pin and rings as 23972.
I must go and search though my stash of spares.....I have this nagging feeling that I used to have a set of Std Hepolite pistons squirrelled away somewhere but perhaps that is wishful thinking!!!    That said the latest challenge is getting the wretched timing side pionon off......it has already chewed up two sets of extractor jaws despite liberal applications of heat and releasing oil!!!
Nick
Hi Nick.
Sounds like the full strip. You don't need to remove the timing pinion from the crank unless you are changing the r/h ball main. Every other job like splitting crankcases, removing conrods etc can be done.  After splitting the c/cases, a blowtorch round the ball bearing housing will expand the alloy and gravity will pull the crank and bearing free. No seal to ruin in that area.
Leave the camshafts in the crankcase if you prefer, but I do recommend removing the intermediate pinion so that the cam lobes are easily positioned for crankcase separation and assembly.
Some extractors from the regular suppliers have jaws that are not flat to follow the sides of the triangular spacer. The radius they put in massively reduces the pulling potential. You could reshape carefully with a file.
I hope you achieve what you are doing.
Roger may have better advice. A true expert.
May I worthy of such praise, Peter! - but I can add nothing useful to your fine contribution. I was obviously lucky with my extractor, as it has always worked well for me. I concur though that the prongs MUST conform to the flat faces of the triangular plate, given the minimal overlap.
Back to pistons: Yes, I was quoting H&G part numbers, as marked on them. The format may be the same as Norton used, but I am aware of no unique-to-lightweight Norton P/Ns below 20xxx, and those unique to the Navi seem to start at 22xxx. Both my 1961/1962 and 1964 Parts Lists cite the same 23972 ID that you noted in yours for the complete piston assembly (standard size).
As for circlips, I have only ever encountered traditional circlips on H&G pistons for the Jubilee, Navigator and Electra, but I do not recall what was supplied with the JP aftermarket items, alas.
Wire clips work well enough for other makers though, albeit that some had turned in ends on theirs, for ease of removal.
Nick, you are using the correct special-to-type half time pinion extractor, I take it, and not a general purpose three jaw puller? The proper tool has an outer sleeve that prevents the legs splaying out as the tension is applied.
Roger
Hi Roger, yes I’m using the correct special tool as you described, bought from the club.   Despite taking great care to line it up correctly and tightening the outer sleeve down really hard to hold the jaws in place and heating the pinion with a blow torch it has only moved about 0.020” and no further.   I’ve gone through three sets of replacement jaws from the club and they just aren’t hard enough.  As I’m sure you know each jaw can only grip on about 1 or 1,5mm of two of the pinion’s teeth so all the force is focused on a tiny area.   As a result the pinion teeth are just cutting through the jaws instead of extracting the pinion.  I’ve tried penetrating oil and serious heat but sadly it just won’t budge after 55 years!   Any ideas would be very welcome!!!
Nick
My general purpose pinion extractor came with jaws for Triumph or BSA pinions but took the NOC spare jaws. I found that I had to loosen the outer sleeve and pull the jaws behind the pinion with cable ties.
As a last resort  you could use a mini grinder and chisel  to split the pinion , assuming you can get a spare.
Hi David and Robert,
Luckily the club has NOS pinions so I’ve ordered one and yet another set of puller jaws from the club.   Today I’m going to split the crank cases and gently drop the crank and main bearing out of the timing side.   Sadly both the club and Norvil are out of stock for Lightweight main bearings so I want to preserve mine which are fine.   Once the crank is out I will have another go at using serious heat and the puller to get it off.   Last resort will be the surgery you suggest but loathe to go that far for fear of damaging the crank!
Does anyone know a reliable source of the correctly ground Lightweight main bearings?
Thanks for the top tips, onwards and upwards!  Nick
