Hi, Just bought a Norvil seat for my 650SS which previously had an aftermarket seat fitted (hence no standard fixings). Has anyone got any drawings or photos of seat fixings? I guess I need: 1. rubber bushes for the two front loops to slide onto the pins on the frame? 2: Rubber buttons to fit into the mid two holes on seat base brackets to rest on top of the frame tubes? 3: Not sure what goes onto the two vertical pins at the rear of the seat base. My Haynes manual doesn't cover this. Otherwise I guess I'll ask/look at a bike at my local club meet when people start bringing out their bikes or ask Norvil. Cheers,
I'd be interested to know…
Pictures please
I'm too interested. On the 650SS I'm working on some vandal has removed the pins in front, so I have to make new ones.
Some answers - more questions
Thanks Mikael - hope these pics of my pins help you.
David - regarding the fixings, I have gleaned from the Norvil site (difficult with no photos) that:
Front bushes are possibly 067790 'Rubber - D - Slimline at Front' - 2 required at £3.85+VAT each
The mid holes do rest on the frame and so I think take the rubber 'buttons' which I have seen on other sites.
The rear seat pins seem to 'hang in the air' on mine, inboard of the suspension unit mounts, without an obvious hole - unless there is some mating bracket which will materialise when I build it back up? (see photo)
The Dzus fastener appears to be 067830 at £3.40 and washer 067829 at £0.50, both +VAT
I have seen the wire Dzus mating part on other sites but not on Norvil. As my bike didn't have mudguards either, it's difficult to see where it fits.
I can't find an exploded sketch or parts list anywhere -- would be grateful if anybody has one?
Cheers.
Just checked some old…
Just checked some old pictures - this was taken some years ago and shows the arrangement from the rear.
https://btcloud.bt.com/web/app/share/invite/pwDQ3wDqr1
The seat pins rest on the brackets above the rear mudguard bolts facing inwards visible here. (The rack is obviously home made - and badly painted at the time this was taken! I retained it with the seat pins, adding rubber bushes under the arms from the bracket to take the lower ends of the seat pins and stop the rack from bouncing around)
The seat was then new and I don't seem to have fitted the Dzus fastener. I think that a secure seat fastening is/was required by MOT test? It does discourage tampering to gain entry to the tool tray.
Thanks David
Thanks for the photo David - I'm pretty sure there were no such brackets fitted when I took the other seat off (it was a Dunstall type, fibreglass 'racing' seat). Better get my metalworking gear out!! I remember, back in the day, a bungee round the seat to hold it down was common! Cheers.
Brackets...
Now that I know what I'm looking for, I can see the rear brackets on the attached exploded frame drawing - right next to nut number 58.
Thanks Mikael
Thanks Mikael - that's really helpful. I think I have a plan. Hope it helped you guys too. Cheers, Len
Just been to the shed to…
Just been to the shed to check and my seat looks exactly like Mikael's. I bought mine direct from Leighton and it came with the rubber bushes and rubber buttons. Maybe Norvil have short changed you if they not include them?
The angle supporting the pins is actually welded to the frame, and not a separate item.
Thanks David, I'll question…
Thanks David,
I'll question Norvil whether their seat should have the rubbers/buttons - just spent over £1200 with them, got no discount and a wait of 2 weeks as they 'lost' my order! I will need to buy a few more bits so no great shakes.
My (new) brackets will be bolted as I've just powder coated the frame and don't really want to grind/weld it.
Cheers,
Mercury seat
Leonard,
I know that my 1968 Mercury is a bit later than your bike but it appears to have the same fixing details with "D" shaped rubbers at the front, rubber buttons in the middle for support on the frame and two pillars at the back with prongs to push into the holes in the right angled bracket by the top of the suspension unit. I think I added rubber washers (tank mounting rubbers) to the rear metal prongs to help support the seat and stop damaging the paint on the brackets.
Whilst fitting the new seat I realised that all my spare control cables would fit neatly under the seat pan by using a couple of cable tidy clips, see photo. An old bicycle tube is useful to protect them and keep them tidy and stop them rubbing the frame. They are then easily available to make repairs or help out a mate!
Philip
Top tip indeed!
Thanks Philip,
The seat looks identical too mine (except I have no rubber bits anywhere - the more I think about this, the more it angers me that Norvil are selling an incomplete seat that you just can't fit to your bike. At least they could warn you that the rubbers aren't included so that you don't need to re-order bits, wait for delivery and pay even more postage!)
Thanks for the top tip on the spare cables - really good idea. Like me, you obviously grew up in the 60s, when riding bikes and driving cars further than the end of the street was a bit of an adventure!!
Cheers,
Len
Len, My seat came from…
Len,
My seat came from Leightons and I don't think it had any rubbers with it either, which is a bit frustrating but seems par for the course if Norvil do the same.
I've only started carrying spare cables since I've been touring i.e.in the last 20 years. The first time I took a couple of spare cables whilst touring in Wales the throttle cable broke up in the mountains, and there was no phone signal. The spare cable was adjusted and allowed me to continue. Perhaps it was because I had a premonition or maybe just luck! Since then I always take a full set of cables when touring the UK or the continent, just to be sure I can get where I'm going.
Regards, Phil.
Frustrating, as you say!
Yes Philip - frustrating.
I must say I didn't know about R K Leighton until you and David mentioned them. I would probably have bought mine from them, had I known, as I prefer to use specialist manufacturers. I'll need a new one for my Commando (or at least a refurb) next, so will certainly give them a look.
I'm refraining from comment on the Wales/phone signal subject - perhaps one has to hope that the cable breaks at the top of a mountain rather than at the bottom - unless it's a brake cable of course?!
Cheers,
Len
Fair spares oops Norvil
At least you got a seat that fitted your frame. Last time I dealt with this pack of thieves and charlatans nothing fitted or was extremely poor quality. It was the first and last dealings I had with them. That was in 1992 it seems that nothing has changed! Les is the most pig ignorant man I have had dealings with in 60+ years of motorcycling.
Holes in the bushes: I…
Holes in the bushes: I bought 2 bushes from the club (last 2??). With a lot of fiddling, got the first one in the front clip, then spotted on the 2nd one the hole is tapered, presumably this matches the frame prongs (my prongs are not original). Panic! Is the first Bush the right way round, as it would be a pig to remove!
Thankfully yes. So be warned, be aware and look carefully at the bushes before you fit them!
PS my seat is a pattern one I bought yonks ago. Let's hope I don't have too many more problems with it - although I'm not yet able to check fit to the dzus screw.
Our 67 Atlas lost its…
Our 67 Atlas lost its dzus mounting in the platers tank so i had to pop rivet a stiffning plate under the guard. .There is also a rubber washer between rear seat bracket and the chrome. If the seat settles on the guard or bathtub on the DL another sturdy washer can be superglued in place which steadies things up.
There used to be a bike…
There used to be a bike breakers in Preston run by two guys, one partner was the nicest, most helpful guy you could ever wish to meet, the other rivalled LE for the title, he would lend you tools to takes something off a dead bike, then refuse to sell it to you 'because you came bugging me for tools', 'I've no change' or even 'because I don't like you'. He actually barred me from the place because I told him that what he said was a Sunbeam S7 frame hanging on the wall was actually a BMW R51.
I'd be interested to know the correct parts. In mine, the front two rubber bushes are actually short lengths of rubber oil hose. The frame has rubber pads about 1/8 ,inch thick glued onto the tip rails where the two intermediate pads rest. The rear two prongs simply enter the holes in the top of the rear spring unit mounts. Then finally is a Dzus fastener into the rear mud guard, which has a wire riveted across the hole.
